Newbie- Label Showing Active Layer
Message 1 of 11
Why won't the following show the Active Layer? (Keep getting the debugger bugging me!)
Private Sub Userform_Activate()
Label3.Caption = ThisDrawing.ActiveLayer
End Sub
Replies (10)
Message 2 of 11
Label3.Caption = ThisDrawing.ActiveLayer.Name
wrote in message news:[email protected]...
bugging me!)
End Sub
Message 3 of 11
Thank you Joe!
I'm also trying to make a listbox showing all of the layers in CAD. When the user selects the layer it becomes active.....
Somebody advised the following but it doesn't seem to do anything:
Private Sub ListBox1_Click()
Dim layerObj As AcadLayer
Set layerObj = ThisDrawing.Layers.Item(ListBox1.Text)
End Sub
Message 4 of 11
That won't work, use the code below:
ThisDrawing.ActiveLayer = ThisDrawing.Layers(ListBox1.Text)
Thank you Joe!
End Sub
Message 5 of 11
To the OP: Note that the solution to both of your problems in this drawing
had to do with data types. You're on the right track, don't get
discouraged. Just note that data types are extremely important, as you're
seeing. Once you get a fair understanding of the differences between
objects (such as AcadLayer), doubles, integers, strings, etc., it will ar
start flowing very nicely.
..........and books like Mr. Sutphin's don't hurt, either. I'd highly
recommend anything he's written about VBA.
"Joe Sutphin" wrote in message
Message 6 of 11
I'm struggling a bit. I am using a combination of Mr Sutphins book (very good BTW) and also my own trial and error.
The following seems to always return the MsgBox before I select the entity......sorry if I'm being annoying 😞
Private Sub CommandButton1_Click()
'Allows user to pick entity that contains desired layer
Dim objDrawingObject As AcadEntity
Dim varEntityPickedPoint As Variant
On Error Resume Next
ThisDrawing.Utility.GetLayer objDrawingObject, varEntityPickedPoint, _
"Choose object to take layer from: "
If objDrawingObject Is Nothing Then
MsgBox "You did not choose an object"
Exit Sub
ThisDrawing.ActiveLayer = objDrawingObject
End Sub
Message 7 of 11
My last example must have slipped past you ...
Dim NewLayer As AcadLayer
Me.Hide
'On Error Resume Next
ThisDrawing.Utility.GetEntity objDrawingObject, varEntityPickedPoint, _
Exit Sub
'change active layer to that of the object selected
Set NewLayer = ThisDrawing.Layers(objDrawingObject.Layer)
ThisDrawing.ActiveLayer = NewLayer
End Sub
Be carefully how you use On Error Resume Next
Exit Sub
End Sub
Message 8 of 11
So close! It all works fine apart from when the user picks nothing and the MsgBox is shown, the program kicks the user out - instead of waiting for another entity to be picked......
I promise that I'll read your chapter on "User Interaction and the Utility Object" before asking any more dumb questions after this one!
Message 9 of 11
Me.Hide
Do
If Not objDrawingObject Is Nothing Then Err.Number = 0
Loop While Err <> 0
End Sub
Message 10 of 11
Excellent, you are as tolerant as a mother with a screaming infant. Consider me back under my rock whilst I do a little more learning. Mind you, smoke me a kipper, as I will probably be back for breakfast! (blooming Inputbox - cancel is annoying me now but I'll save that delight for another time).
Cheers.
Message 11 of 11
The user interaction is actually one of the hardest things to get a handle
on, IMO, particularly if you have any background in lisp.
