newbie. help appreciated
Message 1 of 13
i know vba but am new to autocad. need to loop through all blocks (there's 153 different blocks) and edit the value of the attribute that each block has (attribute has the same name in each block). can anyone please point me to some quality tutorials or examples so i can figure out how to proceed please. i would greatly appreciate it. i'd like to do it w/out selecting anything or using forms. just open the drawing and the values are updated. the updated text will come from a database. i already know this part. just can't find any info on attribute collections or anything to loop through.
thanks in advance.
ms
Replies (12)
Message 2 of 13
const BlName = "myBlockName"
const AttTagString = "myAttributeName"
const NewValue = "myNewValue"
dim tBlRef as acadblockreference
dim tAtts as variant
dim i as integer
dim tSSet as acadselectionset
dim tDXFCode(0) as integer
dim tDXFValue(0) as variant
'first built a selectionset to get all blockrefs you need to change
on error resume next
set tSSet = thisdrawing.selectionsets.add("mySelSetName")
if err.number <> 0 then
set tSSet = thisdrawing.selectionsets("mySelSetName")
tSSet.clear
end if
tdxfcode(0) = 2:tdxfvalue(0) = BlName
tsset.select acselectionsetall,,,tDXFCode,tDXFValue
'for each blockref scan through the attributes
for each tBlRef in tsset
if tBlRef.hasattributes then
tatts=tBlRef.getattributes
for i = lbound(tatts) to ubound(tatts)
if ucase(tatts(i).tagstring = ucase(AttTagString) then
'now we have the attribute to change
tatts(i).textstring = NewValue
exit for
endif
next
end if
next
hope not to make to much typing-errors, - alfred -
In article , mschaffhausen says...
thanks in advance.
> ms
Message 3 of 13
wow. thanks. i'll try out the code. didn't expect you to actually do the work for me. i do have some questions though about the code you posted.
what is a selectionset? i still need one even if i don't have anything selected? there isn't a collection or anything i can loop through?
what do these 2 lines of code do?
if each block in my drawing is unique do i still use acadblockreference or is each one just an acadblock? the drawing was converted from an archview shapefile.
each block has its own name. how do i use your line:
thanks again.
Message 4 of 13
a selectionset gives you a collection of entities filtered by geometry-type, so
you don't have to scan the whole drawing each line, circle, arc, .... to get
only that type of geom you'd like to work on.
the collection (which you missed) is "tSSet", this holds all blockreferences
and with my line "for each tBlRef in tSSet" i do a loop for each blockreference
found.
the definition of what to filter, in this case that means:
tDXFCode(0) = 2...i want to filter for blockname
tDXFValue(0) = "myBlockName" (or the const) ... is the blockname to search for
you mentioned: your blockname is unique doesn't change anything to my example
except that you don't need do loop through the selectionset but to check if
this is found. but carefully (because there are often misunderstandings) for
example you do have a titleblock called "TITLE" and you have placed it 4 times
into your drawing, then you do have ONE block(-definition) but FOUR
blockrefences and only the blockreferences have values in attributes (and will
be vilsible on your drawing.
const BlName = "myBlockName" ==> is just for having a readable sample, simply
change this value to your blockname and the sample works or give it to the sub
as a parameter.
- alfred -
thanks again.
Message 5 of 13
1.a selectionset is like a group, it's an autocad
term.  before you can process a bunch of autocad entities they must first
be selected.  In visual basic this translates to a selection set
object.
2.tdxfcode(0) =
If you are going to program in autocad it's very
imprtant that yo become familiar with group codes.  I think it may be in
autocad's help.  I use a autolisp programming book where they are
listed.  Group codes are basically the way that information regarding
entities are stored in the autCAD 'database'.
3. blocks in autocad are a sort of dictionary
definition.  they are a group of enitities given a name and stored behind
the scenes.  a reference is an instance of the block that actually appears
in the drawing.
4. I believe that BlName here should be "INSERT"
and  tdsxfcode equal 0.  This will select all block entities.
the other selected any entity with a given name.  again, familiarize
yourself with group codes.
Edward
wow.
shapefile.
BlName =
"myBlockName"
thanks again.
Message 6 of 13
sorry to make a little correction
...is exactly what i wanted, because code 2 means "value is blockname" (so i
don't have to add 0|"INSERT" because this is already included.
my sample searches only for blockreferences with the name given at the top of
my code:
- alfred -
In article <6DFE90B8742C3981A16E7178CAFB3091@in.WebX.maYIadrTaRb>,
Ebagby@superstructures.com says...
> object.
2.tdxfcode(0) =
> in the drawing.
Edward
> wow.
> shapefile.
BlName =
> "myBlockName"
thanks again.
Message 7 of 13
thanks again to all of you. i definitely have some reading to do before everything soaks in. i have a somewhat unrelated question that maybe you would be willing to help with. i found another piece of code to loop through the blocks and i thought i'd try it to rename each block to something that made more sense. the names appear somewhat random now from the translation. the drawing is a county map w/ zipcodes. 'zip' is the attribute and each zip code area is it's own (uniquely) named block. i thought i'd rename each block to match the zipcode. the following code gives an error and doesn't rename the block. any thoughts? the error is 'key not found' (#80200014)
Dim blkref As AcadBlockReference
For Each Obj In ThisDrawing.ModelSpace
If TypeOf Obj Is AcadBlockReference Then
Set blkref = Obj
If blkref.HasAttributes Then
AttArray = blkref.GetAttributes
For I = LBound(AttArray) To UBound(AttArray)
If AttArray(I).TagString = "ZIP" Then
'MsgBox AttArray(I).TextString 'returns zipcode
'MsgBox blkref.Name 'returns current block name
blkref.Name = AttArray(I).TextString 'error is here
Next I
Next
thanks again. i truly appreciate it.
Message 8 of 13
that's comes to what i mentioned, please don't get confused on the vocabulary
"Block" and "BlockReference". block is just the definition of how a symbol is
built of where the blockreference is nothing more then a simple geometrytype
like a point including a pointer to the block, to know how it is visualised in
the drawing. and so you cannot change the name of a blockreference (in anouther
programming language you set the pointer to it's BaseClass to ??????.
let's start to what is the goal you want to reach? in case of autocad dealing
witch blockreferences has so much advantages which will all get lost when you
make for every postalcode an own block.
- alfred -
(maybe i don't stay more time today (it's 1 am at my time) but i will follow up
in a few hours after a short sleep)
>   Set blkref = Obj
>      End If
>     Next I
>    End If
>  End If
> Next
Message 9 of 13
i see. after reading your message i was able to get it to work by editing a few lines. here's what i did:
If Attarray(I).TagString = "ZIP" Then 'same as before
myname = blkref.Name 'begin new
Set blk = ThisDrawing.Blocks.Item(myname)
blk.Name = Attarray(0).TextString
getting late here too. i'll pick up tomorrow with the database part. maybe i know enough now to finish it. thanks for everything.
Message 10 of 13
that'ok and now i remember that on one side you said, that your blockref is
unique within your drawing, then this code works.
but do you really have counties (you mentioned each drawing one county) with
only one zip-code?
by the way, it seems that you are working with gis-data, are you using autocad
or autodesk-map? if map, let me know for the next steps today you want to go,
because this could help.
- alfred -
Message 11 of 13
actually i probably wrote the message wrong. the drawing (in autocad 2000, not map) contains shapes that represent each zip code for one county. the map doesn't actually contain counties.
while i'm writing. do you happen to know (don't put much time into it, i haven't done any research yet) if it's possible to test whether a block by name exists? i'm going to loop through a database and compare a value to a possible block by the same name. might not exist and i don't want a error message. don't really want to bypass the issue w/ onerror resume next. also, i was playing w/ the dbconnect function to see if it would do the same thing as my vba code. i could link the drawing to the table but is it possible to link a drawing object or attribute to a query? i need to do an aggregate function (sum) and only want that data to show. probably not the right newsgroup for this question.
thanks,
ms
Message 12 of 13
if you want to check, wether a block(-definition) with a specific name exists:
dim tBlk as acadblock
set tblk = thisdrawing.blocks("yourBlockName")
if (err.number = 0) and (not (tblk is nothing)) then
'ok, the block with name "yourBlockName" is defined in the current dwg
endif
if above test is done, we know if the block is defined (or not), but even if it
is defined, it's not clear wether the block was used (inserted), to check that
you can make the steps with the selection set as mentioned:
tSSet.clear
end if
if tsset.count > 0 '==> ok, there are blockref's used/inserted
- alfred -
thanks,
> ms
Message 13 of 13
once again, thanks for everythings. looks like i have everything i need to get this job done. i appreciate it.
ms
