New drawing?!
New drawing?!
New drawing?!
I'm programming with VB.NET and COM and I need a way to see, when a users saves a drawing, if the drawing is a newly created one.
When I check the command that is send when saving a new drawing, when I press the save button, it sends QSAVE, but then I don't see if it is a new drawing. It should have send Save As... or something... Is there a way to check this!?
Check the document's FullName property.
If it hasn't been saved, it will be an empty string. If it has, it will be the full path and filename.
If ThisDrawing.FullName = "" then 'drawing has not been saved
'do what you want
Mick.
