If you were using A2K, I'd say Tony T's Acadx but you're not. The slow, ugly
way is to cycle through the all the blocks (not inserts) and check their
contents to see if they contain a reference to block you're after:
For i = 0 To ThisDrawing.Blocks.Count - 1
Set blkDef = ThisDrawing.Blocks(i)
For j = 0 To blkDef.Count -1
If TypeOf blkDef.Item(i) Is AcadBlock Then
If blkDef.Item(i).Name = Then
Next
Next
Now remember: I never said this is the *only* way, just the slow and ugly
one.
Attitudes are contagious. Is yours worth catching?
http://www.acadx.com
sfurey < csbent@csbent.com> wrote in message
news:ef47a49.-1@WebX.SaUCah8kaAW...
> Ok, how do you access nested blockrefs?!?
