need tablet guru
need tablet guru
need tablet guru
I have a cal-comp drawing board III with a custom tablet menu written for cad 2000, and I am now wanting to use it with 2009 and when i load the menu all the icons on the tool bar turn into question marks. I have been told the icon bmp files need to be in the menu but I dont know where these icon bmp files are at , can any one help here??
arcticad
You need to add a path into your options at Support File Search Path.
Open the MNU and look for the icon names used.
ID__10 [_Button("ButtonName", "Custom.bmp", "ICON_24_BLANK")]^C^C(command)
You will need to do a search for these files. The path information isn't saved.
in this example Custom.bmp is used.
After the path is set then reload the menu's
(defun botsbuildbots() (botsbuildbots))
