Hi Laurie,
Thanks for your comments they are extremely helpful breaking down how to
approach this task. At first I was thinking of creating a form to create a
single sign at a time. I was pretty sure I could work those the operations
to do that. Ultimately having the ability to read some form of data/text
values and create the entire sign schedule would be the end solution. I
guess if I'm going to work on this I should do as you suggest and work on
something that looks and smells more like the end solution. I might take
longer to create but will be more efficient and powerful.
>AutoCAD drawing as AutoCAD objects ?
The signs will be AutoCAD objects. After creating the sign schedule I then
place the same signs scaled down into the plan view signage plan. much like
a roadway signage plan, just for airports.
> How many different background colours are needed ? Only 3 are shown, red,
green and white
actually black, yellow, white, red. (I changed then so you see yellow on a
white background)
> How many different text messages exist ? It seems there is a relatively
limit set.
I would need a letter for every taxiway name designation
(A,B,C,E,F,D,H,I,J,K, )....and numbers for every runway number (1-36) and
double rw end callouts
17-35 plus and blocks that can't be drawn with text like the arrows and hold
lines as show in the jpeg .
> How easy is it to create a set of columns in Excel
Learning something new is good! I've written to excel but I've yet to read
any data from excel. I'll look for some sample code.
? Would you use a template drawing with the panel square blocks already in
place with maybe attributes or pre-set blocks with known coordinates or in
your option would it be better to use a getpoint and work from there. There
will be cases where I'll need to insert a schedule into a plan drawing.
2005, yes I should get my copy this week. I'll look into the table styles.
Thanks for Your Ideas, They really help.
John Coon
"Laurie Comerford" wrote in message
news:404ac9ce_1@newsprd01...
> Hi John,
> In planning this project ask your self these questions:
> Data entry: In which software will it be easiest to enter the data I
need.
> At first pass it seems as thought Excel would be a winner here.
> It would be easy to enter the data as code on one sheet and query it to
> another or to AutoCAD for presentation
> How are my signs to be presented:
> In an AutoCAD drawing as AutoCAD objects ?
> In an AutoCAD drawing as bitmap objects ?
> In Excel ?
> limit set.
> How many different locations for text exist in a sign ? It seems only 2
if
> you break most of the signs down to a single letter item..
> green and white
> How easy is it to create a set of columns in Excel to uniquely define a
> sign. For example, the first sign in the second row could be
> 4 A G R LA R G E R G RA R G in thirteen columns with the 4 indicating 4
> blocks
> The second sign in the row would be
> 4 A G R Nul R R Nul R R Nul R R where the entry for the letter wouldn't
> matter as both colours are the same.
> Within this system, the first row is different and the first sign could be
> coded with the 2 indicating 2 blocks.
> 2 E G R 17-35 W G and the second as
> 2 E G R 4Row R G
> Can I create an AutoCAD block with a solid background (for which I can
> easily change the colour) and with a single text attribute showing above
it
> It looks from your file that many of the signs could be assembled from 4
> square blocks containing a single character inclusive of:
> Solid coloured letters. Their only appears to be a limited number of
> letters used. You could treat the letter as an attribute of the block or
> make individual blocks (or bitmaps)
> Letters with text outlines which appear in pairs
> Arrows in various directions
> Paired line combinations.
> If your table is to be presented in AutoCAD, I would upgrade to the 2005
> version of AutoCAD before doing any further work. I think you would find
it
> s table facilities would save a lot of programming work.
> Hope this makes sense. I wrote as I thought.
> Laurie Comerford
> CADApps
> www.cadapps.com.au
> "John Coon" wrote in message
> news:404a74e8_3@newsprd01...
> > Group,
> > Every project I do I must create a custom sign schedule for airport
> signage.
> > Currently we use solid and a few blocks to generate the schedule, But
this
> > is
> > very tedious work.
> > I placed a jpeg in the AutoDesk-AutoCAD-customer-files called
> > airportsigns.zip that is a sample of the type of sign schedule I must
> > create.
> > I guess I'm looking for some ideas on how to approach this task with
vba.
> I
> > thought about creating a group of TextBoxes that correspond with each
> panel
> > of the sign and have the TextValue placed in the panel and a CheckBox
for
> > the hatch color to be placed behind the text value. Then I thought want
> > about some type of text file or excel that could be read and have those
> > values placed in the correct panels. I thought that I could use a
> template.
> > Looking for any ideas you might have to automate this process.
> > Thanks, Have a great day.
> > John Coon
