Need MAJOR help
Need MAJOR help
Message 1 of 11
Need MAJOR help
I posted this in Customization and CAD Manager but I know that not everyone
has all the groups in their favorites so I'm posting here in the hopes for
information:
I'm willing to bet only autodesk can answer this one(then again...). Here is
the issue.
I created a company tool bar. I made some BMP Icons for the buttons. One of
the icons I was messing around with and made a face. I went ot put it back
the way it was later, and it wouldnt let me. See the attached image. I
un-installed all of ADT 3.3, deleted the directory and re-installed it... it
is still there!! Where the heck is this image file being held!?!?
Here is the men
u file for our tool bar below. I put a ------------> to show
which one is the icon. whats the deal! Please help.
// The Ritchie Organization menu file - C:\Program Files\Autodesk
Architectural Desktop 3\Support\tro.mns
***MENUGROUP=TRO
***POP1
**TRO
ID_MnTRO [T&RO]
ID_TROButton_10 [TRO &Standards Help]^C^C^P(help "help
"S:/Intranet/doc/Manual of Practice/9997_TRO Manual.chm" ) ^P
ID_TROButton_11 [E-mail .&Geeks](command "start" mailto:help@mail.com)
ID_TROButton_12 [&Clean and
Audit]^C^Cscript;S:/CADstan/Common/Lisp/Clean_Audit.scr;
ID_TROButton_13 [&Layer State Manager]^C^Clman
ID_TROButton_14 [&Update TRO Tools](command "start"
"S:/CADstan/Common/Setup/CAD_Update.vbs")
***TOOLBARS
**TRO_TOOLS
**TB_TRO_TOOLS
ID_TRO_Tools_0 [_Toolbar("TRO Tools", _Top, _Show, 2, 2, 1)]
ID_TROButton_0 [_Button("TRO Standards(MoPP)", "TRO_Help.BMP",
"Icon_16_Blank")]^C^C^P(help "S:/Intranet/doc/Manual of Practic
e/9997_TRO
Manual.chm" ) ^P
-----------------> ID_TROButton_1 [_Button("E-mail Geeks about CAD",
"TRO_Geeks.BMP", "Icon_16_Blank")](command "start" mailto:.Help@mail.com)
ID_TROButton_2 [_Button("Purge, CDGPurge and, Audit", "TRO_CleanUp.bmp",
"Icon_16_Blank")]^C^Cscript;S:/CADstan/Common/Lisp/Clean_Audit.scr;
ID_TROButton_3 [_Button("Layer States Manager", "TRO_LayStateSave.bmp",
"Icon_16_Blank")]^C^Clman
ID_TROButton_4 [_Button("Quick Close", "TRO_QuickClose.
BMP",
"Icon_16_Blank")]^C^Cscript;S:/CADstan/Common/Lisp/QClose.scr;
ID_TROButton_5 [_Button("Update TRO CAD Tools", "TRO_Update.BMP",
"Icon_16_Blank")](command "start" "S:/CADstan/Common/Setup/CAD_Update.vbs")
***HELPSTRINGS
ID_TROBUTTON_0 [The Manual of Professional Practice contains documentation
on our firms standards. Use this frequently.]
ID_TROBUTTON_1 [This button will open up an E-mail to the TRO geeks. You
can ask them about anything CAD or co
mputer related.]
ID_TROBUTTON_2 [This will Purge all, CDGPurge all except for page setups,
and Audit the document fixing any errors 3 times.]
ID_TROBUTTON_3 [This will start the layer states manager for you.]
ID_TROBUTTON_4 [Quick saves and closes active drawing.]
ID_TROBUTTON_5 [By pressing this button you will start the update for TRO
Tools. This will close CAD and copy the needed files to your computer then
open CAD back up.]
// End of The Ritchie Organization me
Files\Autodesk Architectural Desktop 3\Support\tro.mns
Replies (10)
Message 2 of 11
>is
>the issue.
I hope your kidding....
"Icon_16_Blank" is this the icon you want...?
I hard code all bmps. Hate the cute faces...;-)
"c:/my.bmp","c:/my.bmp"
"AlmightySR" wrote in message
news:4840226@discussion.autodesk.com...
information:
the issue.
Here is the men
***MENUGROUP=TRO
***POP1
**TRO
ID_MnTRO [T&RO]
***TOOLBARS
**TRO_TOOLS
**TB_TRO_TOOLS
e/9997_TRO
Manual.chm" ) ^P
BMP",
***HELPSTRINGS
mputer related.]
open CAD back up.]
Message 3 of 11
Hard code means including the path?
"Paul Richardson" wrote in message
news:4840331@discussion.autodesk.com...
>is
>the issue.
Message 4 of 11
yes..
"c:/somefile/your.bmp","c:/somefile/your.bmp"
I keep them all together...Path isn't necessary
if bmps are in your path but...save headaches..
news:4840399@discussion.autodesk.com...
>is
>the issue.
Message 5 of 11
Compiling them into a resource DLL is a great way to avoid these
hassles. Two files in the same folder and it's all squared away.
Message 6 of 11
Solved!
Figure this out... I remove the ARG file and it works! What the heck is
that!?! anyway thank you al lfor the help
information:
the issue.
Here is the men
***MENUGROUP=TRO
***POP1
**TRO
ID_MnTRO [T&RO]
***TOOLBARS
**TRO_TOOLS
**TB_TRO_TOOLS
e/9997_TRO
Manual.chm" ) ^P
BMP",
***HELPSTRINGS
mputer related.]
open CAD back up.]
Message 7 of 11
Frank, How would you call the
bmp from the dll in the mns?
Just curious, I can look it up..)
Thank You,
Paul
"Frank Oquendo" wrote in message
news:4840585@discussion.autodesk.com...
Message 8 of 11
The DLL must have the same file name as the menu file.
You only call the BMP name from the DLL without the ".BMP" extension.
See AfraLisp for everything I've ever learnt about this and to get Resource
Hacker to create the DLLs.
Laurie Comerford
CADApps
www.cadapps.com.au
news:4840647@discussion.autodesk.com...
Thank You,
Paul
Message 9 of 11
Ta, mate
"Laurie Comerford" wrote in message
news:4840656@discussion.autodesk.com...
Laurie Comerford
CADApps
www.cadapps.com.au
Thank You,
Paul
Message 10 of 11
Solved!
Figure this out... I remove the ARG file with the backup and it works! What
the heck is
that!?! anyway thank you all for the help.
information:
the issue.
Here is the men
***MENUGROUP=TRO
***POP1
**TRO
ID_MnTRO [T&RO]
***TOOLBARS
**TRO_TOOLS
**TB_TRO_TOOLS
e/9997_TRO
Manual.chm" ) ^P
BMP",
***HELPSTRINGS
mputer related.]
open CAD back up.]
Message 11 of 11
Did you try deleting the associated .mnr file? By all means, not the .mns. You can actually delete the .mnc (compiled) and .mnr (resource file, holds the bitmaps)
Then reload your menu into AutoCAD (menuload) and the bitmaps should reappear as they were
Mark
