Need help creating a simple leader
NickBrege
NickBrege
I am trying to creating a simple leader in code ... a line with an arrow that points to a feature, connected to a short horizontal line, followed by a single line of text.  I started with this example from the documentation:
Sub Ch5_CreateLeader()
    Dim leaderObj As AcadLeader
    Dim points(0 To 8) As Double
    Dim leaderType As Integer
    Dim annotationObject As AcadObject
    points(0) = 0: points(1) = 0: points(2) = 0
    points(3) = 4: points(4) = 4: points(5) = 0
    points(6) = 4: points(7) = 5: points(8) = 0
    leaderType = acLineWithArrow
    Set annotationObject = Nothing
    ' Create the leader object in model space
    Set leaderObj = ThisDrawing.ModelSpace. _
          AddLeader(points, annotationObject, leaderType)
    ZoomAll
End Sub
My question is how do I specify the text I want to use?  I see there is a reference to an annotation object, but I don't know what I need to do with it.
Can anyone help me out with a code sample that shows what I need to do?  Thanks for any help...
as you can see in the AutoCAD ActiveX Reference Guide, you have to create an "annotation object" to hold the MText (or a Tolerance or a Block) as the object to be "connected" by means of the leader line
while your example is setting this "annotation object" to "nothing" (thus no text shown); you should set it to some MText, as per the following:
Option Explicit
    'create annotation object
    ReDim points(0 To 2) As Double
    points(0) = 10: points(1) = 10: points(2) = 0 '<--| adjust these coordinates as per your needs
    Set annotationObject = ThisDrawing.ModelSpace.AddMText(points, 4, "This is my annotation")
    ' Create the leader object in model space and
    ReDim points(0 To 8) As Double
    ZoomAll
End Sub
NickBrege
Thanks for the help, I got it to work now.  However, the text is not connected to the leader lines in any way.  When I reposition the text, the leader lines don't follow and I can delete each one separately.  They are two completely separate entities.  Is there any way to create it the way Autocad does when I manually add a leader to a drawing?
you could group them in a block
or you could use MLeader object
Sub CreateMLeader()
    ' Define the leader points
    points(0) = 2: points(1) = 2: points(2) = 0
    points(3) = 6: points(4) = 6: points(5) = 0
    points(6) = 6: points(7) = 7: points(8) = 0
    With ThisDrawing.ModelSpace.AddMLeader(points, 0)
        .leaderType = AcMLeaderType.acStraightLeader
        .ArrowheadType = AcDimArrowheadType.acArrowClosed
        .TextString = "This is my annotation"
    End With
End Sub
NickBrege
Thank you ... I will give that a try.
you are welcome
and should my answer solve your question, you may want to come back and mark it as the solution
this will also help other and subsequent forum users
you may want to do that in any other thread you started and got solutions for, too
good coding
