Need a fillet between circle and an arc
Message 1 of 8
I need to create a fillet between circle and an arc. Till now I was trying to use .sendcommand method but didnt get much success. Although i know handle of the objects if somebody can help me using send command and handle objects information for filleting i will appreciate that. One of my object is circle other one is arc. i used this approach still it is not doing exactly i wanted it to do
(1) - acdocument.SendCommand "_fillet (handent " & Chr(34)
& "20CF8" & Chr(34) & ") (handent " & Chr(34) & "20FA6" & Chr(34) & ")"
(2) Another approach I think i can draw a circle using ttr tangent. But My only concern is how can I make sure that this circle should be just on one side which I required and should not be on another side. Does anybody think that I would be a viable thing to do. Is there any method for adding circle using tangent tangent and radius circle method. Please feel free to post your ideas
Replies (7)
Message 2 of 8
Seems like your using a Visual approach to solve a programming problem? i.e. Visually we would draw a circle and an arc then fillet them creating a solution between the two..Code wise you should be looking to just creating the solution and not the construction lines we visually use.. or maybe not.......)? "SehgalS" wrote in message news:230347.1096133714512.JavaMail.jive@jiveforum1.autodesk.com... > I need to create a fillet between circle and an arc. Till now I was trying to use .sendcommand method but didnt get much success. Although i know handle of the objects if somebody can help me using send command and handle objects information for filleting i will appreciate that. One of my object is circle other one is arc. i used this approach still it is not doing exactly i wanted it to do > (1) - acdocument.SendCommand "_fillet (handent " & Chr(34) > & "20CF8" & Chr(34) & ") (handent " & Chr(34) & "20FA6" & Chr(34) & ")" > > (2) Another approach I think i can draw a circle using ttr tangent. But My only concern is how can I make sure that this circle should be just on one side which I required and should not be on another side. Does anybody think that I would be a viable thing to do. Is there any method for adding circle using tangent tangent and radius circle method. Please feel free to post your ideas
Message 3 of 8
If you need to use the fillet command, it requires input similar to what the lisp command (entsel) returns. Which is a 2 element list, the first being the ename, the second being the pick point...... -- Jeff check out www.cadvault.com "SehgalS" wrote in message news:230347.1096133714512.JavaMail.jive@jiveforum1.autodesk.com... >I need to create a fillet between circle and an arc. Till now I was trying >to use .sendcommand method but didnt get much success. Although i know >handle of the objects if somebody can help me using send command and handle >objects information for filleting i will appreciate that. One of my object >is circle other one is arc. i used this approach still it is not doing >exactly i wanted it to do > (1) - acdocument.SendCommand "_fillet (handent " & Chr(34) > & "20CF8" & Chr(34) & ") (handent " & Chr(34) & "20FA6" & Chr(34) & ")" > > (2) Another approach I think i can draw a circle using ttr tangent. But My > only concern is how can I make sure that this circle should be just on one > side which I required and should not be on another side. Does anybody > think that I would be a viable thing to do. Is there any method for adding > circle using tangent tangent and radius circle method. Please feel free to > post your ideas
Message 4 of 8
Can you please send me the syntax, that I can use. Because one I know is not working. I will appreciate your reply
Message 5 of 8
what are you trying to do? besides fillet a line and circle? i.e. what is the arc you are trying to create? "SehgalS" wrote in message news:292420.1096137035423.JavaMail.jive@jiveforum1.autodesk.com... > Can you please send me the syntax, that I can use. Because one I know is not working. I will appreciate your reply
Message 6 of 8
This was the syntax I was using. Here I was just giving the entities through command.
I am also willing to draw a circle using ttr approach. Can you tell me if that is also a viable approach
Message 7 of 8
Here is my code. Basically I am trying to fillet the teeth in the drawing.
Message 8 of 8
Hey look at the code. I have an arc - handle (20FB2) which intersect with circle handle - 20ECE. I need to draw a fillet this arc by selecting this arc and a circle. fillet radius (0.015). I need to automate it completely. See if you can suggest me better approach.
