MText help: how to set the size
NickBrege
NickBrege
I'm adding MText to paperspace but it gets created too big.  Here is the code I am using:
            Dim insertPoint As Double() = {1.0, 1.0, 0}
            Dim noteString As String = "This is my MText."
            doc.PaperSpace.AddMText(insertPoint, 8, noteString)
I can't figure out how to make it smaller.  Is there some font or system variable I need to set first before executing the above code?
If someone could post a small code example or point me in the right direction it would be much appreciated.  Thanks...
sieclaprzemyslaw
Simpliest solution I can think of is to change height of the Mtext after adding:
Dim mT as AcadMText
Set mT=doc.PaperSpace.AddMText(insertPoint, 8, noteString)
'example height of text = 5
mT.height = 5
NickBrege
Thanks, I will give that a try...
Your snippet is not VBA. I think it's VB.NET, so you'd better post your question in the NET forum
anyhow, I could throw in the following guessing
    With ThisDrawing.PaperSpace.AddMText(insertPoint, 8, noteString) 'add the MText object and reference it
        .Height = 5 ' set referenced object height
    End With
which is very similar to sieclaprzemyslaw's one, except it doesn't need to declare the MText object
NickBrege
Thanks for the help guys, that worked.
