MSFlexGrid Control
MSFlexGrid Control
MSFlexGrid Control
MSDN help says that [ColIsVisible] property: ... Returns or sets a value indicating whether a specified column is currently visible. Syntax object.ColIsVisible(index) [=Boolean] ... But when I'm trying to SET a value to a visible column to be not visible (False) I'm getting this error message. "Assignment to constant not permited" The MSDN help says that I'm trying to set a value to a readonly property. The column index is a valid number, by the way.
Microsoft web help solve my problem. It says: Returns a value indicating whether a specified column is visible currently. A column is not visible when it is outside the client area of the control's window - in other words, when it is scrolled out of view. So I was misusing this property confusing with column-hide/show, desired, properties "vbTorture" wrote in message news:41daf3f4$1_2@newsprd01... > MSDN help says that [ColIsVisible] property: > ... > Returns or sets a value indicating whether a specified column is currently > visible. > Syntax > > object.ColIsVisible(index) [=Boolean] > > ... > > But when I'm trying to SET a value to a visible column to be not visible > (False) I'm getting this error message. > "Assignment to constant not permited" > The MSDN help says that I'm trying to set a value to a readonly property. > The column index is a valid number, by the way. > >
