More help needed on Layouts
I'm having a hard time adding a layout then making the new layout current.
I can add the new one just fine, but I can't get it to become active using
code.
Thanx in advance
Michael Browne
Try posting the code you're having the problem with,
as it's hard for someone to guess what it does.
Otherwise, this should do it:
set ThisDrawing.ActiveLayout = ThisDrawing.Layouts.Add("New Layout")
> code.
> Thanx in advance
> Michael Browne
/* Tony Tanzillo Design Automation Consulting */
/* Programming & Customization for AutoCAD & Compatibles */
/* [email protected] */
/* http://ourworld.compuserve.com/homepages/tonyt */
Tony,
That doesn't want to work either. Here's my code. Its inside a form that
has a textbox
and two buttons
Private Sub CommandButton1_Click()
Set ThisDrawing.ActiveLayout = ThisDrawing.Layouts.Add("New Layout")
Unload Me
End Sub
Thanks for the help
Michael Browne
Tony Tanzillo wrote in message <[email protected]>...
current.
using
>> code.
>> Thanx in advance
>> Michael Browne
Tony's code worked just fine for me. Are you getting an error message?
"Michael Browne" wrote in message
news:[email protected]...
> Tony,
> has a textbox
> and two buttons
> Unload Me
> End Sub
> Thanks for the help
> Michael Browne
> current.
> using
> >> code.
> >> Thanx in advance
> >> Michael Browne
My guess is that it may be failing because the form is
active. You might want to try closing the form first,
before trying to make the layout active.
> Tony,
> has a textbox
> and two buttons
> Unload Me
> End Sub
> Thanks for the help
> Michael Browne
> current.
> using
> >> code.
> >> Thanx in advance
> >> Michael Browne
It still does not work. The error I keep getting is:
Run-time error '438':
Object doesn't support this property or method
It does create the new layout but it just won't switch to it
>> Tony,
that
>> has a textbox
>> and two buttons
>> Unload Me
>> End Sub
>> Thanks for the help
>> Michael Browne
>> current.
>> using
>> >> code.
>> >> Thanx in advance
>> >> Michael Browne
Eliminate the 'Set' before ThisDrawing.ActiveLayout and
it will work:
ThisDrawing.ActiveLayout = Thisdrawing.Layouts.Add("New Layout")
