Modeless forms
Modeless forms
Modeless forms
When I design a user form as modeless, I cannot keep the focus on the
modless form (the focus always pops back to the Autocad Application window).
I click on any object in the modless form and have it respon (ie command
buttons, check boxes, etc...), but the form does not retain the focus to
allowing typing into a text box.
I am using Autocad 2002.
AutoCAD sends messages to all child windows to see if they want to
retain focus when the mouse cursor moves off of the window. The
VBA form is probably responding to the message and that's causing
AutoCAD to take the focus. I believe that Autodesk has some kind of
ActiveX control to deal with this.
Bill
"Joe LeBaron" wrote in message
news:[email protected]...
window).
You could bring up a modal InputBox upon the click event of the text
box, then pump it's results back into the text field. It's not good but
its only workaround I know.
Terry
Yikes... Effective but ugly.
"Terry W. Dotson" wrote in message
> Terry
Add reference to "C:\Program Files\Common Files\Autodesk
Shared\AcFocusCtrl.dll".
The control has a property "KeepFocus". Set it to True.
> > Terry
Thanks Ravi that is a gem of a tip.
I have one problem with it though, and it is probably something easy, but when I react to
a "enter" in a text box with a standard KeyDown event, I don't seem to be able to put
the focus back on the text box afterwards, and consequently have to click on it to enter
more info.
Kent
"Ravi Pothineni" wrote in message
> > > Terry
I am trying to do the same thing with acad 2ki but I do not have the dll
file, is there another way to do this in a2ki ?? or is there somewhere I can
get it from ??
Many thanks
Mark
but
> > > Terry
