Modeless,AcFocusCtrl1 and GetEntity
Roughly I have a dialog box with the following
1. the main module sets my dialog to Modeless
2. One button to select an object “cmdGetObj”
3. one button to exit “cmdExit”
When I select the getobj button I am prompter to select an object.
(and possible I will have a loop to select objects)
The problem is that because the form is modless, I can also select the exit button……
But the exit only unloads the form and the user is still prompted to select a point.
How can I set it up so that the cmdExit will not only unload the form but will also exit the “getEntity” or any other command ?
'main program
UserForm1.Show modeless
UserForm1.AcFocusCtrl1.KeepFocus = True
Private Sub cmdGetObj_Click()
ThisDrawing.Utility.GetEntity returnObj, basePnt, "Select object to revise"
Endsub
Private Sub cmdExit_Click()
Unload Me
End Sub
You could handle it in two ways (may be more) to not allow user to close the
form until picking is done.
1. Set a UserForm level flag to indicate now is picking or not. If is, you
will not allow form to be closed. The code looks like:
Private picking as Boolean
Private Sub CommandButton1_Click()
On Error Resume Next
'Set picking flag
picking = True
Dim basePnt As Variant
Dim returnObj As AcadEntity
revise"
'Clear picking flag
picking = False
If returnObj Is Nothing Then
MsgBox "No entity is picked."
Else
MsgBox "Entity is picked."
End Sub
Private Sub UserForm_QueryClose(Cancel As Integer, CloseMode As Integer)
If picking Then
Cancel = 1
Exit Sub
'Other cleaning up code when UserForm is closing
End Sub
2. You can disable UserForm during picking, so it cannot be closed until
picking is done. The code lopks like:
'Disable the form
Me.Enabled = False
revise"
'Enable the form back
Me.Enabled = True
Else
End Sub
wrote in message news:5452343@discussion.autodesk.com...
2. One button to select an object "cmdGetObj"
3. one button to exit "cmdExit"
button..
a point.
will also exit the "getEntity" or any other command ?
'main program
Endsub
Unload Me
End Sub
thanks Norman
But I was hoping that there was a way that in the cmdExit not only could I undload the form but also terminate the command. ThisDrawing.Utility.GetEntity returnObj, basePnt, "Select object"
I guess that is how I should have worded my query in the first place, in this discussion group.
All the same I appreciate your effort in replying....Thanks
Can someone please comment if this is good programming practice, normally I am against using the sendcommand in VBA.
to exit out of the getEntity I have revised my cmdExit to the following, the chr(3) sends an ESC key to the command prompt.
ThisDrawing.SendCommand Chr(3)
Unload Me
End Sub
