Method 'Origin' of object 'IAcadBlock' failed
taras_zelensky
taras_zelensky
Hello
When creating a block, I want to add a polyline to it:
Sub Example_AddPolyline()
' This example creates a polyline in model space.
Dim blkDef1 As AcadBlock
Dim plineObj As AcadPolyline
Dim points(0 To 10) As Double
Dim Middle2(0 To 2) As Double
Middle2(0) = 1: Middle2(1) = 1
' Define the 2D polyline points
points(0) = 1: points(1) = 1
points(2) = 1: points(3) = 2
points(4) = 2: points(5) = 2
points(6) = 3: points(7) = 2
points(8) = 4: points(9) = 4
' Create a lightweight Polyline object in model space
Set blkDef1 = ThisDrawing.Blocks.Add(Middle2, "111")
blkDef1.AddPolyline (points) '<-- There is a mistake
Set plineObj = blkDef1.AddPolyline(points)
plineObj.Closed = True
End Sub
But an error occurs: "Method 'Origin' of object 'IAcadBlock' failed"
What is the possible solution to this problem?
grobnik
Hi, @taras_zelensky
I made a simple test with your code, the issue it's inside the amount of points, defining the polyline, these shall be multiple of 3, you defined the array of 11 points (0 to 10), and assigned array variable from 0 to 9.
Here below code reviewed
Dim points(1 To 9) As Double 'You set Dim points(0 To 10) As Double
'points(0) = 1: ' point 0 deleted in order to reach 9 points
points(1) = 1
End Sub
Let us know
taras_zelensky
Many thanks for the help. Everything is working 🙂
Dim points(0 To 11) As Double
points(0) = 1: points(1) = 1: points(2) = 0
points(3) = 1: points(4) = 2: points(5) = 0
points(6) = 2: points(7) = 2: points(8) = 0
points(9) = 2: points(10) = 1: points(11) = 0
ThisDrawing.ModelSpace.InsertBlock Middle1, "111", 1, 1, 1, 0
End Sub
