Macro Warning dialog
I have an Excel file with Macro's in it. There are as many as 100 tabs within the XLS file. I use OLE Linking to bring that XLS file into AutoCAD & save the drawing. Whenever the drawing is opened, I get the 'Enable Macros' warning dialog for every sheet linked in (possibly clicking Enable Macros 100+ times). I've found that within Excel this warning can be removed by creating a Certificate & adding the the Certificate Publisher (myself) as trusted, but this only works in Excel. AutoCAD does not respect that Trusted Publisher list. How can I disable this Enable Macro's message in AutoCAD?
Please keep in mind I'm not a VBA programmer. Thanks!
have you tried various expert settings?
type expert into the command line and you can choose levels from 0 to 5, 0 being that all warnings are shown, and 5 being that almost none are shown.
A good idea squid, but unfortunately it did not work.
