Macro security message
Message 1 of 1
All, This isn't a typical macro security prompt that I've seen. We have a DVB deployed, the 'Enable macro virus protection' in UNCHECKED. However, one 1 machine we receive the following message: Microsoft Forms This application is about to initialize ActiveX controls that might be unsafe. If you trust the source of this file, select OK... and this prompt appears 6 times per usage. The project references the following: VBA AutoCAD 2000 Type Library OLE Automation Microsoft Forms 2.0 Object Library AutoCAD Color OLE AutoCAD Lineweight/Linetype VBScript Regex 5.5 AutoCAD Layer OLE ActiveX Data Objects 2.5 AutoCAD Focus Control for VBA Windows Common Controls Everything has been regsvr32'd (i.e. the OLE and Focus libs). Any ideas ?
Replies (0)
