Macro recorder
Macro recorder
Macro recorder
Hello Joe Sutphin,
I was trying to use the macro recorder that you have created, but have unfortunately run into trouble. This is mainly because I have never run macros before in CAD.
After I load the .dvb project in the VBA Manager I am unable to see any macro in the Macro Window. I was wondering if I am doing something wrong.
Your help is really appreciated.
Start the recorder by typing VBARUN on the command line. Then select the
"Record" macro in the list.
Next, do something like draw a circle or line. When you have completed the
drawing of an entity, a dialog box will popup asking you for a macro name.
Give it some name Line1 or Circle1 or whatever you want.
Once you click on OK the macro [source code] to recreate the entity you just
drew is created in the NewMacros module.
That's pretty much it. I have attached the original file in case you have
gotten hold of a bogus one. I ran this morning and it seems to work just
fine.
Joe
wrote in message news:5200636@discussion.autodesk.com...
Hello Joe Sutphin,
Hello Joe,
I have a question. I'm doing something wrong or your macro only records one instruction?
Do you know the way to record a sequence of actions made?
Thanks a lot!!
Francesc
Hi Joe:
I have a question. Where am I suppose to put the file FreeVBAMacroRecorder.zip?
Please help me out.
Thank you.
Diana.
Hi Diana,
You need to save the .DVB file contained in the .ZIP somewhere on your hard
drive [perhaps in an AutoCAD support folder]. Then load it like any other
DVB file and execute it. HTH, let me know if you need anything further by
either replying to the newsgroup or email me directly.
Joe ...
wrote in message news:5617329@discussion.autodesk.com...
Hi Joe:
Please help me out.
Thank you.
Diana.
Hi Joe,
Maybe this is an ever repeated question, but it looks that your macro allows for only one command before it asks for the name of the generated macro and then exits. Please confirm, and if so, would you please expand it so that it could cover an indefinite number of commands?
Thanks and best regards,
Amine Salameh, CEng, MIWO
Sorry, I have not dealt with the recorder for quite
awhile now. However, it does seem to be working properly from the behavior you
describe.
Additionally, I don't have any plans to work
on it as I'm extremely busy with .NET projects.
Joe ...
Hi
Joe, Maybe this is an ever repeated question, but it looks that your macro
it could cover an indefinite number of commands? Thanks and best regards,
