Looping through attributes
Hi there. Let me try to explain what's my problem.
I've inserted a block with attributes in the drawing. The names (TagString)
of the attributes are written in the following format DAN1, DAN2, DAN3, ....
Now what I'm trying to do is make an array of all attribute references and
then loop through them until I find the one I'm looking for and then change
it's value (TextString) to a certain date that is written in textbox.
I thought that if I write a code like this all the attributes with the name
DAN + something should be assigned a value of Datum variable. But nothing
happens.
Public Sub IzpisiDan()
Dim Datum As Variant
Dim objAttRef As AcadAttributeReference
Dim varAttributes As Variant
Dim intAttLoop As Integer
Dim intSteviloDni As Integer
Dim intI As String
Dim Dan As String
Datum = Format(txtDatumStart.Text, "dd.mm.")
intI = 0
varAttributes = objHarm.GetAttributes
For intAttLoop = LBound(varAttributes) To UBound(varAttributes)
intI = intI + 1
Dan = "DAN" & intI
Set objAttRef = varAttributes(intAttLoop)
If objAttRef.TagString = Dan Then
objAttRef.TextString = Datum
Next
ThisDrawing.Application.Update
End Sub
But if I change that loop that it looks only for a specific attribute it
works.
intI = 1
Dan = "DAN" & intI
Next
If anyone knows what I'm doing wrong or if you have a better idea how to do
that task please let me know.
Thank you.
Marko
This is off the top of my head.....
'*******just for each your way through the array************
for each objAttRef in varAttributes
if objAttRef.tagstring like "dan*" then
end if
next objAttRef
End Sub
"Make the most of the best
and the least of the worst."
Robert Louis Stevenson
http://www.acadx.com
To the best of my knowledge, you can't use For Each
on arrays.
Your code seems fine, except that you should use
the Like operator to test the variable.
If objAttRef.TagString Like "dan*" Then ....
"Marko Rogic" wrote in message
news:728880B2AB60406CD563292C975073DD@in.WebX.maYIadrTaRb...
(TagString)
change
name
> happens.
> Dim intI As String
> Dim Dan As String
> intI = 0
> intI = intI + 1
> Dan = "DAN" & intI
> End If
> Next
> End Sub
> works.
> intI = 1
> Dan = "DAN" & intI
> End If
> Next
do
> Thank you.
> Marko
Actually as of VB6, I don't know about earlier versions, you can...with some
caveats. The element of the for each...next must be a variant. Also, the
element is passed by value. This case doesn't demonstrate it well, but I
can see where this could cause some serious logical errors causing one to
pull out large quantities of hair.
So Marko, while my for each...next suggestion is technically feasible, I
can't really say that it's advisable. Keep your for...next loop. Good
luck.
> Actually as of VB6,
For Each works with arrays in VBA5 as well.
Learn to think outside the book.
"Bobby C. Jones" wrote in message
news:C552750852B1400F393A57EB5E9BB47D@in.WebX.maYIadrTaRb...
some
the
> luck.
Thanks for your input people, I'll try your suggestions ASAP.
Marko.
"Frank Oquendo" wrote in message
news:32CDAF0820F6160D057F410DB9AA64BB@in.WebX.maYIadrTaRb...
> > Actually as of VB6,
> some
> the
I
to
> > luck.
