Loop is closing more drawings then needed
I have to open up 2 blank drawings sometimes because it will close down additional drawings. In my extract Sub, I do not have any function or anything to close down a drawing. For some reason, it will get to the .close, and close the one drawing right behind it before closing the active drawing. Any ideas of how to fix this error?
~Thanks
For h = 0 To (intListCount - 1)
With Application
.Documents.Open lstElemDwgs.List(h)
Extract_TB_RefBlocks 'Extract Elem Diagrams
.ActiveDocument.Close
End With
Next h
'Reset users SDI mode
Application.ActiveDocument.SetVariable "SDI", PreviousSDIMode
Why not control which doc you want to use?
Dim oDoc as AcadDocument
With Application
Set oDoc = .Documents.Open (lstElemDwgs.List(h))
oDoc.Close
End With
hth
Mark
wrote in message news:5821986@discussion.autodesk.com...
~Thanks
With Application
End With
Next h
Thanks you for the response. This solved my problem
~Cheers
Glad that helped.
Mark
wrote in message news:5823016@discussion.autodesk.com...
~Cheers
