Loading VBA files - display clean Command Line
Message 1 of 1
when I load the VBA via:
(defun c:tst ()    ( vl-vbarun  "Path/DVB.dvb!Testing.test" ))
The code runs without any problems but the command line display several lines with location of the code. Is there a way to make the command behave like other commands with a clean command line sowing only the command input?
Thank you,
-J
Replies (0)
