Loading th color picker in VBA for autocad 2008
Hi all
I have a problem in loading the color picker in autocad 2008 using the VLAX class module, althought it was working well in autocad 2006.
The following represent the code for the VLAX class module:
Private VL As Object
Private VLF As Object
Private Sub Class_Initialize()
    Set VL = ThisDrawing.Application.GetInterfaceObject("VL.Application.16")
    Set VLF = VL.ActiveDocument.Functions
End Sub
Private Sub Class_Terminate()
    Set VLF = Nothing
    Set VL = Nothing
End Sub
Public Function EvalLispExpression(lispStatement As String)
    Dim sym As Object, RET As Object, retVal
    Set sym = VLF.Item("read").funcall(lispStatement)
    ' on error resume next
    retVal = VLF.Item("eval").funcall(sym)
    If Err Then
        EvalLispExpression = ""
    Else
        EvalLispExpression = retVal
End Function
Public Sub SetLispSymbol(symbolName As String, value)
    Dim sym As Object, RET, symValue
    symValue = value
    Set sym = VLF.Item("read").funcall(symbolName)
    RET = VLF.Item("set").funcall(sym, symValue)
    EvalLispExpression "(defun translate-variant (data) (cond ((= (type data) 'list) (mapcar 'translate-variant data)) ((= (type data) 'variant) (translate-variant (vlax-variant-value data))) ((= (type data) 'safearray) (mapcar 'translate-variant (vlax-safearray->list data))) (t data)))"
    EvalLispExpression "(setq " & symbolName & "(translate-variant " & symbolName & "))"
    EvalLispExpression "(setq translate-variant nil)"
End Sub
Public Function GetLispSymbol(symbolName As String)
    symValue = value
    GetLispSymbol = VLF.Item("eval").funcall(sym)
End Function
Public Function GetLispList(symbolName As String) As Variant
   Dim sym As Object, list As Object
   Dim count, elements(), i As Long
   Set list = VLF.Item("eval").funcall(sym)
   count = VLF.Item("length").funcall(list)
   ReDim elements(0 To count - 1) As Variant
   For i = 0 To count - 1
        elements(i) = VLF.Item("nth").funcall(i, list)
   Next
   GetLispList = elements
End Function
Public Sub NullifySymbol(ParamArray symbolName())
    Dim i As Integer
    For i = LBound(symbolName) To UBound(symbolName)
        EvalLispExpression "(setq " & CStr(symbolName(i)) & " nil)"
    Next
End Sub
The line code highligthed in red is the line where an error occurs for the autocad2008
So does anyone know whats wrong with this module and also is there another way to call the autocad color picker?
Thanks 4 ur help.....................
norman.yuan
Having not used VLAX, I could be wrong.
Change "VL.Application.16" to "VL.Application.17"
"16" means AutoCAD version 16 (Acad2004/5/6), "17" means Acad2007/8/9
Norman Yuan
Drive CAD With Code
Thanks 4 ur reply, I tried it but still same error occurs
Thanks again....
norman.yuan
OK, it looks like, VL.Application.16 is the one you can use. There is no VL.Application.17/18...
I tried with my 2 computers with this code:
Public Sub Test()
    Dim vl As Object
    Set vl = ThisDrawing.Application.GetInterfaceObject("VL.Application.16")
    MsgBox "Done"
End Sub
Box1: OS Win2003 (Should be the same as WinXP) with Acad2006, 2008 2009 installed.  The code works with all of them: Acad2006, 2008, 2009
Box2: Win7 (32bit) with Acad 2009,2011 installed. The code does not work (getting error "Problem in loading application") with both Acad2009 and 2011.
Norman Yuan
Drive CAD With Code
Ok, so its not easy to fix this module.
But do u know another way to load the color picker in VBA?
Thanks again 4 ur help...
Here is an example of using Windows color palette. You pick a color from it and then you can convert it to RGB and use this color to the objects. First attachment is the code for picking the color from palette and convert it to RGB with function from the second attachment.
One question what is VLAX, for what it's?
andrewpuller3811
I found the attached file with the routine to call the autocad colour dialogue somewhere, sorry to the original author for not recalling who it was.
The code below is part of a sub that uses the attached routine to set form button colours
    Dim lngLastSrfceTriColor As Long
    Dim blnMetaColor As Boolean
    Dim lngCurClr As Long
    Dim lngInitClr As Long
    Dim lngRed As Long
    Dim lngBlue As Long
    Dim lngGreen As Long
    Dim retCol As New AcadAcCmColor
        'store colour for reference
        lngLastSrfceTriColor = retCol.ColorIndex
        'set color method to enable grabbing colour by colour index
        retCol.ColorMethod = AutoCAD.acColorMethodByACI
        ' Set retcol from surface point style
        retCol.ColorIndex = SrfcWrkgStyle.TriangleStyle.DisplayStylePlan.color
        ' check if current surface point colour matches last chosen colour.
        ' i.e the button colour
        If retCol.ColorIndex = lngLastSrfceTriColor Then
            lngInitClr = retCol.ColorIndex
        Else
            lngInitClr = lngLastSrfceTriColor
        ' grab the RGB properties of the current layer colour
        lngRed = AutoCAD.Application.ActiveDocument.ActiveLayer.TrueColor.Red
        lngGreen = AutoCAD.Application.ActiveDocument.ActiveLayer.TrueColor.Green
        lngBlue = AutoCAD.Application.ActiveDocument.ActiveLayer.TrueColor.Blue
        ' Set retcol from RGB components of current layer
        Call retCol.SetRGB(lngRed, lngGreen, lngBlue)
        'Set the long of the current layer colour index
        lngCurClr = retCol.ColorIndex
        ' Not sure what this property is
        blnMetaColor = True
        On Error Resume Next
        'the line below always generates an error - don't know why hence error ignoring
        If acedSetColorDialog(lngInitClr, blnMetaColor, lngCurClr) Then
        On Error GoTo 0
            'Get Surface Style Point Color
            retCol.ColorIndex = lngInitClr
            'Store chosen colour for checking later
            lngLastSrfceTriColor = lngInitClr
            ' Check returned colour and if 0 or 256 set colout to button face
            ' and text to byblock or bylayer, otherwise set to colour
            Select Case lngInitClr
                Case 0
                    Me.cmdbtnTriColour.BackColor = vbButtonFace
                    Me.cmdbtnTriColour.Caption = "ByBlock"
                Case 256
                    Me.cmdbtnTriColour.Caption = "ByLayer"
                Case Else
                    Me.cmdbtnTriColour.BackColor = RGB(retCol.Red, retCol.Green, retCol.Blue)
                    Me.cmdbtnTriColour.Caption = ""
            End Select
And the function that calls the autocad colour picker dialogue
Public Declare Function acedSetColorDialog Lib "acad.exe" (color As Long, _
                ByVal bAllowMetaColor As Boolean, ByVal nCurLayerColor As Long) As Boolean
If a post provides a fix for your issue, click on "Accept as Solution" to help other users find solutions to problems they might have that are similar to yours.
Andrew Puller
Maitland, NSW, Australia
Windows 11
Intel core i7 11800 @ 2.30 GHz with 32GB Ram
Civil 3d 2023
