ListView.ListItems 1 based or 0 based?
I was told here recently that .ListItems collection is 0 based
But I have tried numerous times to confirm that and can find no settings
which make it work.
I've tried all four settings for LV.View and none of them make it work
I've tried with and without .ColumnHeaders and neither makes it work....
Can anyone enlighten me on what I'm doing wrong?
I keep getting out of bounds error with oLV.ListItems.Item(0)
using this test ...
(you can replace LogEntry and LogError with Debug.Print
Sub EnumListItems(oLV As ListView)
Dim lChek As Long, sRpt As String
'norman yuan(whom I greatly respect and am sure is right) says ListItems
is zero based but I get out of bounds error on it
'For lChek = 0 To oLV.ListItems.Count - 1
CheckBase1:
On Error GoTo Base1Err
Debug.Print "Try 1 based collection"
For lChek = 1 To oLV.ListItems.Count
If oLV.ListItems.Item(lChek).Selected = True Then
sRpt = sRpt & "Item " & CStr(lChek) & " Selected " & vbCrLf
Else
sRpt = sRpt & "Item " & CStr(lChek) & " Not Selected " & vbCrLf
Next lChek
CheckBase0:
On Error GoTo Base0Err
Debug.Print "Try 0 based collection"
Else
Next lChek
Debug.Print "Selected items oLV: " & vbCrLf & sRpt
ExitHere:
On Error GoTo 0
Exit Sub
EnumListItems_Error:
Err.Clear
Resume ExitHere
Base1Err:
Debug.Print "Base-1-Err"
Err.Clear
Resume CheckBase0
Base0Err:
Debug.Print "Base-0-Err"
Err.Clear
Resume ExitHere
End Sub
The first row is 1, with the headers (whether they are on or not) occupying
0 (altho thats not how you access the column headers). Similarly, the
checkbox uses up subitem(0) whether you use them or not, so your first
column is always at 1 and the number of columns is
listview.ListItems.Item(1).ListSubItems.Count
Also, the last row is given by listview.listitems.count, not
listview.listitems.count-1
Jon
"MP" wrote in message
news:5773489@discussion.autodesk.com...
which make it work.
using this test ...
CheckBase1:
Else
Next lChek
CheckBase0:
Else
Next lChek
ExitHere:
On Error GoTo 0
Exit Sub
Err.Clear
Resume ExitHere
Base1Err:
Err.Clear
Resume CheckBase0
Base0Err:
Err.Clear
Resume ExitHere
End Sub
Thanks for the confirmation Jon,
Then ListView.ListItems is 1 based as is a collection
That's what I find in testing.
Maybe I misunderstood Norman, cause I know he knows his stuff!
If the Header is 0 as far as rows go, that doesn't make ListItems 0 based,
just theres a row before ListItems starts.
at least I can quit thinking I'm losing my mind because of the inability to
access item(0)
...so it must be due to some other cause ......!!
Mark
"jon" wrote in message
news:5773552@discussion.autodesk.com...
Jon
which make it work.
using this test ...
CheckBase1:
Else
Next lChek
CheckBase0:
Else
Next lChek
ExitHere:
On Error GoTo 0
Exit Sub
Err.Clear
Resume ExitHere
Base1Err:
Err.Clear
Resume CheckBase0
Base0Err:
Err.Clear
Resume ExitHere
End Sub
>>to
>>access item(0)
There's not much chance of keeping your sanity when dealing with vba 🙂
Jon
