listbox
listbox
Message 1 of 9
listbox
if i have a listbox with the multiselect property set to extended how do i
create a button to remove all the selected items or add them to another
listbox?
thanks,
Rob
w2k, vb6, a2k2
Replies (8)
Message 2 of 9
you can use the removeitem method. here's an example that you may be able to
use in your code.
lstExistBlks.RemoveItem (lstExistBlks.ListIndex)
"Rob Tomson" wrote in message
news:EFF239DEF7733338448E318E7BF69865@in.WebX.maYIadrTaRb...
> listbox?
> thanks,
> Rob
> w2k, vb6, a2k2
Message 3 of 9
i know how to do that but if i have more than one item selected then
.listindex only returns the currently selected item. how do i remove (or
add) them all?
"Russell Cygan" wrote in message
news:14DA20A663C69A9FAC2E00E71164F04C@in.WebX.maYIadrTaRb...
to
> use in your code.
i
> > listbox?
> > thanks,
> > Rob
> > w2k, vb6, a2k2
Message 4 of 9
From the MSDN Library:
MultiSelect Property Example
This example fills a ListBox control with the names of your screen fonts and
illustrates how the MultiSelect property affects the behavior of a ListBox.
To try this example, create two ListBox controls and a CommandButton control
on a form. In the first ListBox, set the MultiSelect property to 1 or 2. At
run time, select several items in the first ListBox, and then click the
CommandButton. All selected items are displayed in the second ListBox. Run
the example several times with different settings of the MultiSelect
property. Paste the code into the Declarations section, and then press F5 to
run the program.
Private Sub Form_Load ()
Dim I ' Declare variable.
' Fill the list box with screen font names.
For I = 0 To Screen.FontCount - 1
List1.AddItem Screen.Fonts(I)
Next I
End Sub
Private Sub Command1_Click ()
' Clear all items from the list.
List2.Clear
' If an item is selected, add it to List2.
For I = 0 To List1.ListCount - 1
If List1.Selected(I) Then
List2.AddItem List1.List(I)
Next I
End Sub
HTH
Veign
Designing Solutions
www.veign.com
VB Code Samples & Projects
www.veign.com/information/info_main.html
news:2F84D10178904090E0B54836376BDA78@in.WebX.maYIadrTaRb...
> add) them all?
able
> to
> > use in your code.
do
> i
another
> > > listbox?
> > > thanks,
> > > Rob
> > > w2k, vb6, a2k2
Message 5 of 9
have you tried creating an array of all the selected items as you select
them so you can use the removeitem using these as listindexes rather than
just the currently selected one?
> add) them all?
able
> to
> > use in your code.
do
> i
another
> > > listbox?
> > > thanks,
> > > Rob
> > > w2k, vb6, a2k2
Message 6 of 9
there has to be an easier way to do this...
news:AFD523A8E50165D7849B9C4EE33612D1@in.WebX.maYIadrTaRb...
(or
> > add) them all?
> able
> > to
> > > use in your code.
how
> do
> > i
> another
> > > > listbox?
> > > > thanks,
> > > > Rob
> > > > w2k, vb6, a2k2
Message 7 of 9
thanks, that works like a champ but now how do i remove the selected items?
"Veign" wrote in message
news:A825845389D422F7EC8288E9B8630E81@in.WebX.maYIadrTaRb...
and
ListBox.
control
At
to
> run the program.
> Next I
> End Sub
> List2.Clear
> End If
> Next I
> End Sub
> HTH
> Veign
> Designing Solutions
> www.veign.com
(or
> > add) them all?
> able
> > to
> > > use in your code.
how
> do
> > i
> another
> > > > listbox?
> > > > thanks,
> > > > Rob
> > > > w2k, vb6, a2k2
Message 8 of 9
This has worked for me:
Private Sub CommandButton2_Click()
Dim nEntryNumber As Integer
Dim j As Integer
Dim flag As Integer
flag = 0
nEntryNumber = 0
Do While nEntryNumber < ListBox1.ListCount
If ListBox1.Selected(nEntryNumber) = True Then
For j = 0 To ListBox2.ListCount - 1
ListBox2.ListIndex = j
If ListBox1.List(nEntryNumber) = ListBox2.List(j) Then
flag = 1
Next j
If flag = 0 Then
ListBox2.AddItem ListBox1.List(nEntryNumber)
ListBox1.RemoveItem nEntryNumber
Else
nEntryNumber = nEntryNumber + 1
flag = 0
Loop
End Sub
news:4D6E0A6CDBFE15229BFB58B1E0D8CBD7@in.WebX.maYIadrTaRb...
than
> (or
> > > add) them all?
> > able
> > > to
> > > > use in your code.
> how
> > do
> > > i
> > another
> > > > > listbox?
> > > > > thanks,
> > > > > Rob
> > > > > w2k, vb6, a2k2
Message 9 of 9
just do the same thing when you check for selections, but don't use the
for...next - loop :
Dim A As Integer
A = -1
Do
A = A + 1
If List1.Selected(A) Then
List2.AddItem List1.List(A)
List1.RemoveItem (A)
A = A - 1
Loop Until A = List1.ListCount - 1
news:FEDD39E5265E0516283F02BF7B4945D5@in.WebX.maYIadrTaRb...
items?
> and
> ListBox.
> control
> At
Run
F5
> to
> > run the program.
> > Next I
> > End Sub
> > List2.Clear
> > End If
> > Next I
> > End Sub
> > HTH
> > Veign
> > Designing Solutions
> > www.veign.com
> (or
> > > add) them all?
> > able
> > > to
> > > > use in your code.
> how
> > do
> > > i
> > another
> > > > > listbox?
> > > > > thanks,
> > > > > Rob
> > > > > w2k, vb6, a2k2
