Listbox problems
Listbox problems
Listbox problems
I'm a novice VB / VBA person and I've run into yet another roadblock.
I'm trying to move a group of drawing files from one listbox (that displays
the total list of files in a subdirectory) to another. This second listbox
is the group of drawings I'm going to perform the operation on.
the problem is: I keep getting an "invalid property array index" error
(code 381) in the section of code that removes the selected items (after its
added to the second listbox). My code, as far as I know, is in accordance
with every book and reference I've seen. What am I doing wrong ?
Dim i As Integer
For i = 0 To filelist.ListCount - 1
If filelist.Selected(i) Then
lstDrawings.AddItem dirname & filelist.List(i)
Next i
Dim k As Integer
For k = 0 To filelist.SelCount - 1
If filelist.Selected Then <<< this is where the error
code is initiated
filelist.RemoveItem (k)
Next k
The second section of code is where the error occurs (see my comment to the
right of the code).
If you have a suggestion, please email: nimzondn@mindspring.com
or just post your recommendations
thanks
jm
hi john,
the problem at this point is that you don't give an index to selected
if filelist.Selected(k) 'should be the syntax
then you run in to more problems
first is that you have to count not to (SelCount-1) but to (ListCount -1)
second problem is, that vb evaluates the listcount at the beginning of the
loop and not during running in the loop, as you delete items in the list you
will get an index-error. ie your loop starts with values from 0 to 3, you
delete listitem 2, then 3 is missing and your loop fails. you can return the
loop if you do
for i=(filelist.ListCount -1) to 0 step -1
then your job should be done
regards, alfred
___________________________________________________________
Alfred Neswadba
Ingenieur Studio HOLLAUS
A-3100 St.Poelten, Brandstroemg. 6..... +43 699 21807303
Internet ................................ www.hollaus.at
E-Mail ...................... alfred.neswadba@hollaus.at
"john" schrieb im Newsbeitrag
news:2D9D26622E20ECB3DCB5D7BC738B3B58@in.WebX.maYIadrTaRb...
displays
listbox
its
> Dim i As Integer
> End If
> Next i
> Dim k As Integer
> code is initiated
> End If
> Next k
the
> right of the code).
> thanks
> jm
It worked wonderfully. I appreciate the help.
I'm amazed at the quality of help I recieve in this discussion group.
john
Alfred Neswadba wrote in message
news:E397A02D6F34DF1B5D69D783EBB6675D@in.WebX.maYIadrTaRb...
> hi john,
you
the
> loop if you do
> regards, alfred
> Alfred Neswadba
> displays
> listbox
> its
accordance
> > Dim i As Integer
> > End If
> > Next i
> > Dim k As Integer
> > code is initiated
> > End If
> > Next k
> the
> > right of the code).
> > thanks
> > jm
