lisp to rotate text and objects to a giving ucs coordinates
GuillermoAQ
GuillermoAQ
I'm looking for a lisp routine that could rotate text (encase by rectangle and wipeout), to a giving ucs coordinates.
My job is to rotate all this text to ther proper sheet set up of each individual drawing.
I will really appreciated any help or advice or suggestions.
More information can be provided is required.
Guillermo Quijano
Hi GuillermoAQ,
First make up your mind whether you want to limit the solution to lisp,
or to any programming language which will perform the task.
If you want lisp to the exclusion of other solutions, then post your
request in the customisation newsgroup rather than this one which is for
VBA.
Let us know before someone spends time creating a solution you don't want.
Regards
Laurie Comerford
GuillermoAQ wrote:
> Hello, I'm looking for a lisp routine that could rotate text (encase by
> rectangle and wipeout), to a giving ucs coordinates. My job is to rotate
> all this text to ther proper sheet set up of each individual drawing. I
> will really appreciated any help or advice or suggestions. More
> information can be provided is required. Regards, Guillermo Quijano
GuillermoAQ
Thanks Laurie
My apologies wrong forum.
Please disregard this post, I will repost under lisp.
