LineStart and LineEnd to excel
Message 1 of 11
Hello everyone,
I´m creating a VBA application in Excel that takes objects from AutoCAD and places it´s properties in an Excel sheet. (With the properties from this sheet i want to create a SVG file.)
Writing layer, color, handle, name and text to excel works beautifully using the acax17enu.tlb library. example:
Dim ent As AcadEntity
Dim Excel As Object
Dim excelSheet As Object
Dim entLayer As String
entLayer = ""
entLayer = ent.Layer
excelSheet.Cells(R, 1).Value = entLayer
and voila the layer is in column A
I also neet Start and Endpoint of a line or path of a polyline and center of circles etc. For now I use the Getpoint function to acquire these points:
dim startpoint as variant
dim x as double,y as double,z as double
StartPoint = ThisDrawing.Utility.GetPoint(Prompt:="Pick Insert Point:")
x=startpoint(0)
y=startpoint(1)
z=startpoint(2)
excelSheet.Cells(R, 7).Value = x
excelSheet.Cells(R, 8).Value = y
the function requires you to interactively select the points rather than automatically selecting startpoint and endpoint. Is there another way to do this?
Are these points in another library maybe?
Or can I get the Getpoint function to automatically select certain points?
Thanks!
Replies (10)
Message 2 of 11
You could simply loop through ModelSpace looking for targeted entities by,
say, entity type (AcadLine, acadCircle, AcadBlockreference...) and get the
needed information. Example code:
Dim ent AS AcadEntity
Dim l as String
Dim p as Variant
For Each ent in ThisDrawing.ModelSpace
l=ent.Layer
excelSheet.Cells(...).Value=l
If TypeOf ent Is AcadLine Then
'You know Line by AcadLine.StartPoint and AcadLine.EndPoint
'Then add the point/property value to Excel Sheet
ElseIf TypeOf ent Is AcadCircle Then
'You get center point of the Circle: AcadCircle.Center
ElseIf TypeOf ent Is....
Else
End Id
Next
Of course if you only are interested in certain type of entity and if the
drawing is big, you could easily use SelectionSet with proper filter to get
targeting entities a lot faster than looping through whole MS.
wrote in message news:5789164@discussion.autodesk.com...
Hello everyone,
Dim Excel As Object
entLayer = ""
x=startpoint(0)
y=startpoint(1)
z=startpoint(2)
this?
Thanks!
Message 3 of 11
thnx for your input, i'll try this monday and reply
Message 4 of 11
Still can't get it to work. First of all AcadLine.StartPoint and AcadLine.Endpoint are not recognized but AcadLine.Start and AcadLine.End are. i've build in a messagebox to check them but they do not have a value...
Dim p1 as Variant
Dim p2 as Variant
For Each ent In SSET2
p1 = AcadLine.Start
p2 = AcadLine.End
MsgBox p1
MsgBox p2
'excelSheet.Cells(R, 11).Value = p1
'excelSheet.Cells(R, 12).Value = p2
what am i doing wrong?
Message 5 of 11
I do not know whcih Acad you use, but AcadLine has property StartPoint and
EndPoint, whcih is variant type (double array). So, you cannot MsbBox p1.
The code would look like:
Dim l as AcadLine
For Each ent in SSET2
Set l=ent
MsgBox "Start X=" & i.StartPoint(0) & vbCr & Start Y=" &
l.StartPoint(1) & vbCr & "Start Z=" & I.StartPoint(2)
'Update Sheet here
Next
wrote in message news:5790529@discussion.autodesk.com...
value...
Dim p1 as Variant
Dim p2 as Variant
p1 = AcadLine.Start
p2 = AcadLine.End
MsgBox p1
MsgBox p2
Message 6 of 11
i've spend all afternoon trying to figure out why my StartPoint etc are not accepted. I can find them in my objectlist but can't add them to my code. i'm using acad 2008
Message 7 of 11
Although I do not have acad2008 installed, but I think it ( AcadLine's
StartPoint/EndPoint properties) is still there (if not, Autodesk will be
buried in flood of angry rants).
Probably you mean the intellisense does not show StartPoint/EndPoint when
you type code in VBA IDE. That is because
either
You have wrong code in previous lines. You could do compile to dig it out;
Or
If you have code like you showed in previous code, it, of course, should not
show the intellisense prompt, because you did not cast AcadEntity into
AcadLine entity. It should look like:
Dim l as AcadLine
Set l=ent '''Only after this line, you can have
StartPoint/EndPoint shown in intellisence prompt.
p1 = l.StartPoint
p2 = l.EndPoint
MsgBox p1
MsgBox p2
Next
Since I do not have Acad2008, I am only 99.9999% positive AcadLine stiil
have StartPoint/EndPoint properties (if not I would quit doing anything with
Acad at all), in the case (0.00001% chance) that StartPoint/EndPoint not
exist any more, then sorry, you have do your own study on Acad2008 VBA.
wrote in message news:5790775@discussion.autodesk.com...
i'm using acad 2008
Message 8 of 11
Trust me, these properties are still there. 🙂
"Norman Yuan" wrote in message
news:5791252@discussion.autodesk.com...
Message 9 of 11
FINALLY! It works! Norman thanks a bunch!
This is my final code for extracting linecoordinates to excel, for anyone who's interested.
Sub AutoCADEntities()
Dim AutoCAD As acadapplication
Dim Thisdrawing As AcadDocument 'as Object
Dim activedocument As Object
Dim SSET2 As Object
Dim Excel As Object
Dim application As Object
Dim c As Integer, R As Integer
Dim Line As AcadLine
Dim startpunt As Variant
Dim eindpunt As Variant
Dim x2 As Double, y2 As Double, z2 As Double
Dim x As Double, y As Double, z As Double
On Error Resume Next
'get excel if app already open
Set Excel = GetObject(, "Excel.Application")
If Err <> 0 Then
Err.Clear
'create/open excel if not
Set Excel = CreateObject("Excel.Application")
'handle excel error if app cannot be opened.
If Err <> 0 Then
MsgBox "Could not load Excel.", vbExclamation
End
Excel.Visible = True
'add a new work book
'Excel.Workbooks.Add
'select Worksheet named "Sheet1"
Excel.Sheets("Sheet1").Select
Set excelSheet = Excel.ActiveWorkbook.Sheets("Sheet1")
' I do this a couple of times, because ocassionally, in my projects, the first attempt fails
Set acadapp = GetObject(, "autocad.application")
Set Thisdrawing = acadapp.activedocument
Set acadapp = GetObject(, "AutoCAD.Application")
Apptivate
' = sub for activating the autocad window you want to use
Set SSET2 = Thisdrawing.SelectionSets.Add("strSet3")
R = 1
SSET2.SelectOnScreen
AppActivate ("Microsoft Excel")
Set Line = ent
startpunt = Line.startpoint
eindpunt = Line.endpoint
x = startpunt(0)
x2 = eindpunt(0)
y = startpunt(1)
y2 = eindpunt(1)
excelSheet.Cells(R, 1).Value = x
excelSheet.Cells(R, 2).Value = x2
excelSheet.Cells(R, 7).Value = y
excelSheet.Cells(R, 8).Value = y2
R = R + 1
Next ent
good luck
Message 10 of 11
> Dim SSET2 As Object
> Dim Excel As Object
> If Err <> 0 Then
> Err.Clear
> If Err <> 0 Then
> End
> End If
> End If
> Apptivate
> R = 1
> Set Line = ent
> x = startpunt(0)
> x2 = eindpunt(0)
> y = startpunt(1)
> y2 = eindpunt(1)
> End If
> R = R + 1
> Next ent
> good luck
Instead of testing to see if it's a line within the loop:
Use filters on your selection set to select only lines.
It's much quicker. Always keep your loops to the minimum possible. There are numerous example on the web.
Dave F.
Message 11 of 11
Sorry, Rick
I'll don't recommend the similar code to
somebody else
This looks ugly for me
If you want to write it in the good manner,
please take a look at this page for example:
http://www.excelguru.ca/node/10
~'J'~
