Line
Line
Message 1 of 12
Line
how can i control a line
if the StartPoint and endPoint are parallel to X axis
Replies (11)
Message 2 of 12
It's not quite clear what you're asking. Maybe a bit more explanation would help. Perhaps the Z values of your Start and End point are set to something other than 0. Just a wild guest at this point.
Joe
Message 3 of 12
Only what i need is checking for straight
line
 i  try like this
 If Entity.Angle <> 0
Then
    MsgBox "Line is NOT parallel to X axis... note
endpoint"
But when Angel is 180 i have  the same
i like to do something like if angle
<> 0 or <>180 then
It's
Joe
Message 4 of 12
if y coordinates are equal
style="BORDER-LEFT: #000000 2px solid; MARGIN-LEFT: 5px; MARGIN-RIGHT: 0px; PADDING-LEFT: 5px; PADDING-RIGHT: 0px">
line
 i  try like this
Then
endpoint"
<> 0 or <>180 then
It's
Joe
Message 5 of 12
but how to do ??
line
 i  try like this
Then
endpoint"
<> 0 or <>180 then
It's
Joe
Message 6 of 12
Here, I wrote you a little function that returns whether the line is parallel to the X axis.
Joe
Public Function ParallelToXAxis() As Boolean
Dim oEntity As AcadEntity
Dim Point As Variant
Dim oLine As AcadLine
On Error Resume Next
ThisDrawing.Utility.GetEntity oEntity, Point, "Select line "
If Err Then Exit Function
If TypeOf oEntity Is AcadLine Then
Set oLine = oEntity
If oLine.Angle = 0 Or oLine.Angle = 180 Then ParallelToXAxis = True
End Function
Message 7 of 12
Warning! That last post is wrong. Unfortunately, the AutoCAD documentation is in error. The following, however,
works fine.
Joe
Set oLine = oEntity
With ThisDrawing.Utility
If .AngleToString(oLine.Angle, acDegrees, 0) = 0 Or .AngleToString(oLine.Angle, acDegrees, 0) = 180 Then
End With
End Function
Message 8 of 12
thanks
Warning!
works fine.
Joe
Dim oEntity
As AcadEntity
    Set oLine =
oEntity
    End
With
End Function
Message 9 of 12
Na, the code in your last post looks fine, you just forgot that the
angle property returns a value in radians, not degrees.
Just for giggles, using your original idea about the elements:
if oLine.startpoint(0) = oLine.endpoint(0) then ParallelToXAxis = True
-Josh 🙂
> works fine.
> Joe
Message 10 of 12
Which makes it wrong because it didn't have the AngleToString functions [which I would have had
had I not relied on the documentation].
Joe
Message 11 of 12
Hi Joe,
True, the docs do say dgrees and I see your point, I should have looked a
little closer at the change in your second post. I just glanced at it
and thought you went the anglefromXaxis route. Not criticizing or
anything, but to explore yet another route, how about:
If oLine.Angle = 0 Or oLine.Angle = PI Then ParallelToXAxis = True
Obviously, this is something you probably would want to limit to even
increments of degrees, but for even increments it's a breeze to convert
on the fly once you start looking at it as PI radians = 180 degrees and
2PI radians = 360 degrees,,,,
PI/12 = 15
PI/6 = 30
PI/2 = 90
PI = 180
3(PI/2) = 270 'or 3 X 90 = 270, ect.
2PI = 360
yatta, yatta, yatta
-Josh
> Joe
Message 12 of 12
That's an option. However, now I have to toat around the function to get Pi instead of using the AutoCAD built-in function of AngleToString. I guess it's a personal preference thing 'cause either way works.
Joe
