LDT3 and Dockable Container
When I try to load a window created with the accont.arx I get an "out of memory error" at the command line. AutoCAD continues to work fine, I just can't load the container. Any ideas? Any one else have this problem?
John
Have you tried loading it any other AutoCAD
based product?
"jah5869" wrote in message
news:f109088.-1@WebX.maYIadrTaRb...
> Thanks,
> John
Yes. It works fine in ADT3.3,Map5, and plain AutoCAD2002.
John
It's possible that LDT3 is doing something funky at startup.
Have you tried using the DOCKABLE_CONTAINER command to load
the dockable container once LDT3 is running?
Also verify that the installed version of AcCont.arx/tlb is
the same one you developed the container with.
news:f109088.1@WebX.maYIadrTaRb...
> John
