Layer object behavior
In the code snippet below, I am wondering why I have to set the objLayer
object to Nothing before I can create the second and third layers, when I
take "Set objLayer = Nothing" out the code never changes the objLayer
variable besides the first time. Shouldn't the "Set objLayer =
ThisDrawing..." lines just overwrite without having to first clear the
variable or is this expected behavior? I am using VBA 6 w/ Acad2002.
On Error Resume Next
Set objLayer = ThisDrawing.Layers("S-GRID")
If objLayer Is Nothing Then
Set objLayer = ThisDrawing.Layers.Add("S-GRID")
MsgBox "Unable to Add S-GRID Layer " & vbCr & Err.Description
Set objLinetype = ThisDrawing.Linetypes("Center2")
If objLinetype Is Nothing Then
ThisDrawing.Linetypes.Load "Center2", "C:\Program Files\AutoCAD
2002\Support\acad.lin"
If Err Then
MsgBox "Error loading CENTER2 linetype" & vbCr &
Err.Description
objLayer.Color = 9
objLayer.Linetype = objLinetype
Set objLayer = ThisDrawing.Layers("S-GRID-IDEN")
Debug.Print Err.Description ' take this out later
Set objLayer = ThisDrawing.Layers.Add("S-GRID-IDEN")
MsgBox "Unable to Add S-GRID-IDEN Layer " & Err.Description
objLayer.Color = acGreen
Set objLayer = ThisDrawing.Layers("S-GRID-IDEN-TEXT")
Debug.Print Err.Description ' take this out later too
Set objLayer = ThisDrawing.Layers.Add("S-GRID-IDEN-TEXT")
MsgBox "Unable to Add S-GRID-IDEN-TEXT Layer " & Err.Description
objLayer.Color = acWhite
matthew g.
Matthew,
Here's your answer.
Joe
Dim objLayer As AcadLayer
'load linetype upfront
ThisDrawing.Linetypes.Load "Center2", "C:\Program Files\AutoCAD 2002\Support\acad.lin"
If Err.Description <> "Duplicate record name" Then
MsgBox "Unknown error loading linetype", vbCritical, "Error loading linetype"
Else
Err.Clear
With objLayer
.Color = 9
If Err = 0 Then
.Linetype = "Center2" 'Center2 loaded
Else
.Linetype = "Continuous" 'no, default to standard linetype
End With
With objLayer
.Color = acGreen
End With
With objLayer
.Color = acWhite
End With
> Matthew,
> Here's your answer.
Thanks Joe. So the difference was in loading the linetype up front or in
the way that you handled the error trapping? Perhaps both? And more
importantly, what is the logic behind that?
matthew g.
> Shouldn't the "Set objLayer = ThisDrawing..." lines just overwrite without
having to
> first clear the variable or is this expected behavior?
It would overwrite if the right hand side (ThisDrawing...) did not produce
an error. When the named layer does not exist, an eror is produced when
evaluating the RHS, and error handling skips down to the next line without
resetting objLayer. I think you were expecting
ThisDrawing.Layers("NonExistentLayer") to return Nothing... it doesn't, it
just returns an error.
Joe's code gets around this by Joe's knowing that if you .Add a layer that
already exists, it returns the existing layer. I didn't know VBA would do
this, and it seems like a useful feature... but to me, intuitively, it seems
most "proper" for VBA to throw an error if you try to Add something that
already exists. I'm not complaining, I just wouldn't have guessed it would
work like that.
James
> an error.
(snip)
Thank you extremely for the explanation, it makes a lot more sense now.
matthew g.
