Killing Excel after tool execution
Message 1 of 8
Hi all,
Attached is a small program that creates an Excel file.
The problem with this program is- the EXCEL does not get killed after the program execution, which can be seen in the Process list of Task Manager.
The attachment contains the VB source program, it's EXE file and a GIF showing the living EXCEL in TaskManager.
Please execute the EXE with TaskManager open and feel the problem.
What changes should I make in the program to solve this problem? Any suggestions most appreciated.
MNRaghu
Replies (7)
Message 2 of 8
Search the group as this has been covered multiple times.
G'Luck
Bob Coward
Message 3 of 8
set excel = nothing
Matt W
"What the flip was Grandma doing at the sand dunes?"
Message 4 of 8
xlApp.Quit
Set xlApp = Nothing
Set xlSheet = Nothing
Set xlWbk = Nothing
You must Set each object to Nothing in the EXACT reverse order of their
creation.
wrote in message news:5193461@discussion.autodesk.com...
Hi all,
MNRaghu
Message 5 of 8
Jeff Mishier,
That did the trick. Thanks.
Bob Coward and Matt,
Thanks you too for the replies.
(Matt - Your suggestion gave error.)
MNRaghu
Message 6 of 8
I didn't open the ZIP file so I don't know EXACTLY what you wrote or what your variables were. I was just thinking back to a
previous program that I wrote a while back which extracts attributes to Excel and counts/totals them.
I completely forgot about the reverse order thing that Jeff had mentioned.
Glad you got it working though.
Matt W
Message 7 of 8
Aubelec
hello.
easy : do not use the function range. use only cell(x,y) the objet range create a pointer (one selection) but when you quit excel. the pointer is not release --> excel do not quit.
and use only a var for all your app; in excel. for use a selection cell. :
set selec = excelpage.cell(x,y)
selec.value = "rrrr"
do not try this : excelpage.cell(x,y).value = "rrr"
with this you do not release the selection. is hard to earn but with the trick excel quit properly.
Message 8 of 8
Aubelec,
Thanks for the nice tip.
MNRaghu
