KeyDown-KeyUp, how do I make it work on a form?
Message 1 of 8
How in the world do I get a VBA UserForm to acceppt KeyDown and KeyUp, I
can get the following to work in text boxes but not on the form:
NO WORKY:
Private Sub UserForm_KeyDown(ByVal KeyCode As _
MSForms.ReturnInteger, ByVal Shift As Integer)
msgbox KeyCode
End Sub
YES WORKY:
Private Sub txtBoxIamHere_KeyDown(ByVal KeyCode As_
msgbox KeyCode
End Sub
any ideas?
I know this is VBA and in VB I think I might ise keypreview or similar to
sniff out keys. any ideas?
thanks joseguia
Replies (7)
Message 2 of 8
Jose Guia had this to say:
> any ideas?
If this is related to your form hide idea, my suggestion will stop
working as soon as the form is hidden from view (nothing on the form
has the focus). The rest of the time, you can simply forward the
KeyAscii parameter to the form's KeyPress procedure from any of the
controls on that form:
Private Sub TextBox1_KeyPress(ByVal KeyAscii As MSForms.ReturnInteger)
Call UserForm_KeyPress(KeyAscii)
End Sub
http://www.acadx.com
"If you want to be somebody else change your mind"
Message 3 of 8
Because a VBA UserForm does not support a KeyPreview property like VB the key events will occur only on the control that has focus. A form can have the focus only if it has no controls on it or all its visible controls are disabled. Hence, if you have controls such as a TextBox on your form then key events will occur only for the controls and not the form unless you disable all the controls first.
Joe
Message 4 of 8
but this solution will prevent you from entering text in your control...
Message 5 of 8
That is what I wanted to know.
thanks
so I would be better off putting the
keydown
Because
first.
Joe
Message 6 of 8
Ezeckiel had this to say:
> control...
No, it will not.
Message 7 of 8
It's just a bad practice for one event to be calling another event.
Joe
"Frank Oquendo" wrote in message
news:18C343794D1B2B447A911C7BF4C0A994@in.WebX.maYIadrTaRb...
> > control...
> No, it will not.
Message 8 of 8
Joe Sutphin had this to say:
> Joe
Lots of programmers would disagree with you, including me. There's
nothing "bad" about using message chains. Hooks rely on the passing of
parameters from one procedure to another. So do derived classes, or
have you never seen a call MyBase.New()?
