Iterating controls?
Iterating controls?
Message 1 of 11
Iterating controls?
Hi guys,
I have a form with about 20 checkboxes on it and I need to perform a
similar action for each box that is checked. Rather than monotonously
using :
if check1.value = true then,,,,,if check2.value=true then
ect., ect,
I'm trying to access them in a loop such as:
dim cbox as checkbox
for each cbox in form1 or for each cbox in form1.controls
or
for I = 0 to form1.controls.count, ect.
The problem is that I cannot access the controls collection in the form
to get a count and a variable defined as a checkbox stays set to nothing
when it hits the loop. I did not create a controls array when I added
these to the form, they're all individuals. Did I mess up? How can I
loop through the checkboxes on a form?
-Josh
Replies (10)
Message 2 of 11
Are you using vb or vba? Vba does not use control arrays on forms, so you have to handle it differently. Ed
Message 3 of 11
Josh,
Perhaps this will help.
Dim ctl As Control
Dim chk As CheckBox
For Each ctl In UserForm1.Controls
If TypeOf ctl Is CheckBox Then
Set chk = ctl
Debug.Print chk.Value
Next ctl
Joe
"Minkwitz Design" wrote in message news:3C484C67.5000302@ameritech.net...
> Hi guys,
> using :
> ect., ect,
> or
> -Josh
Message 4 of 11
Dan,
Use something like the following to iterate all the controls in the form -
select case to deal with the ones you need:
Dim varControl As Variant
Dim objControl As Control
For Each varControl In Me.Controls
Set objControl = varControl
Debug.Print objControl.Name
Next varControl
Mike Weaver
> Hi guys,
> using :
> ect., ect,
> or
> -Josh
Message 5 of 11
Thanks guys,
That did it. To address the question, I'm using vb 6. Your posts made me
recognize the error of my ways 🙂 Addressing the objects in the form as
by a specific type rather than as a contol (as object) first, then
checking type. I used the method Joe specified since I'm more familiar
with it, with the minor exception that (for future ref) I didn't have to
address the controls collection. ie -
for each ctl in form1
if typeof ctl = checkbox then
Thanks again for the help guys,
-Josh
Joe Sutphin wrote:
> Josh,
> Dim ctl As Control
> Dim chk As CheckBox
> Set chk = ctl
> End If
> Next ctl
> Joe
>>Hi guys,
>>using :
>>ect., ect,
>>or
>>-Josh
Message 6 of 11
You should consider switching to a control array; that will allow you
to use a single routine to handle all the click events.
Good judgment comes from experience.
Experience comes from bad judgment.
http://www.acadx.com
news:3C485632.9030109@ameritech.net...
> Thanks guys,
Message 7 of 11
Josh,
Your choice is identical, it's just implicit using
the Controls collection instead of explicit.
Incidentally, that will not work in VBA, you
must explicitly use the Controls collection.
Joe
"Minkwitz Design" wrote in message news:3C485632.9030109@ameritech.net...
> Thanks guys,
> -Josh
> Joe Sutphin wrote:
> > Josh,
> > Dim ctl As Control
> > Dim chk As CheckBox
> > Set chk = ctl
> > End If
> > Next ctl
> > Joe
> >>Hi guys,
> >>using :
> >>ect., ect,
> >>or
> >>-Josh
Message 8 of 11
Hi Frank,
That's a good point and I'll have to try and remember that for future
reference. But in this instance, I'm not even looking at the events. I
simply have a list of checkboxes and a couple of command buttons. I
check the boxes I want and hit run, then vb accesses a database and runs
a sql query relevant to each box that was checked and fills out word
docs accordingly with the info retrieved.
But that brings up another question. How do you insert the autotext for
"page x of y" in the footer of a word doc from vb/vba?
-Josh
>>Thanks guys,
Message 9 of 11
Hi Joe,
That would explain it. While debugging, I tried it both ways and it
worked in either case. But again that was vb not vba. For the sake of
consistency, I may start adding that so I don't stub my toe attempting
the same thing in vba. Thanks for the clarification.
-Josh
Joe Sutphin wrote:
> Josh,
> Joe
>>Thanks guys,
>>-Josh
>>Joe Sutphin wrote:
>>>Josh,
>>> Dim ctl As Control
>>> Dim chk As CheckBox
>>> Set chk = ctl
>>> End If
>>> Next ctl
>>>Joe
>>>>Hi guys,
>>>>using :
>>>>ect., ect,
>>>>or
>>>>-Josh
Message 10 of 11
One way would be to just set up a template that you could use when you open a new doc. Ed
Message 11 of 11
I used a similar construction to iterate over labels on a form...I wrote a
mouse over that would underline, and change the color of the label as well
as swap in the "hand" as the mouse cursor (ala internet explorer)...to
differentiate between labels as controls and labels not being used as
controls, I made use of the "tag" property...
"Joe Sutphin" wrote in message
news:23BCAD429EF4520BF82171378672A5B5@in.WebX.maYIadrTaRb...
> Josh,
> Joe
> > Thanks guys,
> > -Josh
> > Joe Sutphin wrote:
> > > Josh,
> > > Dim ctl As Control
> > > Dim chk As CheckBox
> > > Set chk = ctl
> > > End If
> > > Next ctl
> > > Joe
> > >>Hi guys,
> > >>using :
> > >>ect., ect,
> > >>or
form
nothing
> > >>-Josh
