Is it possible to change attributes' values from VB6?
From my VB6 project , using ObiectDBX, I can read attributes' values without opening the draw. Can I edit(change) them also?
I tried something like:
Dim varattribs As Variant
varattribs = objblockref.GetAttributes
For i = 0 To UBound(varattribs)
If varattribs(i).TagString = attr_name Then
varattribs(i).TextString = attr_value
Next i
....then I save the draw.
The varattribs variant array is filled but this code doesn't change the values of the attribute
What's wrong? Is it possible?
Tank you in advance for your help: It is very important for me to know (fast) if it is possible.
Try calling the Update method of either the attribute entity or its parent
block.
Tools you can use: get your free copy of ProPack
http://www.acadx.com
"egiuliani" wrote in message
news:ef4ec33.-1@WebX.SaUCah8kaAW...
> End If
> Next i
THANK YOU! THANK YOU! THANK YOU!
