intersectwith question
I'm using intersectwith to check polylines for intersections. The command
outputs an array of intersection coordinates. I want to test if the two
items intersect or not but the following causes a type mismatch error:
dim retval as variant
retval = ssetObj.Item(c).IntersectWith(ssetObj.Item(d), acExtendNone)
If retval <> Null Then **Type mismatch
I tried Empty as well with the same result. If anyone has an answer TIA.
Scott Nelson
Technical Director
Scenery Plastics Inc.
www.sceneryplastics.com
I answered this as follows:
If UBound(retval) > LBound(retval) Then
"Scott" wrote in message
news:ef1d566.-1@WebX.SaUCah8kaAW...
> Scott Nelson
> Technical Director
Nicely done. That's a pretty short way to do it.
eXtending the power of AutoCAD
http://www.acadx.com
Scott wrote in message
news:ef1d566.0@WebX.SaUCah8kaAW...
