intersection point vbempty argument
MakCADD
MakCADD
I amd trying to find the intersection points of objects in selection set.   If the intersection point is nothing I need to perform a task if not do some thing else.  here I am getting the first first task done for both result
here is the code
For b = 0 To BarrSet.Count - 1
For C = 0 To ContSet.Count - 1
Set Cline = ContSet.Item(C)
Set BLine = BarrSet.Item(b).Copy
IntPt = BLine.IntersectWith(Cline, acExtendNone)
If VarType(IntPt) <> vbEmpty Then
ThisDrawing.ModelSpace.AddCircle Cline.EndPoint, 1
If VarType(IntPt) = vbEmpty Then
MsgBox "ASDFASDF"
BLine.Delete
Next
Next
you have to check If the returned variant is an empty array of Double (just check Ubound(returnedVariant) against -1) instead of a VbEmpty Variant
moreover I'd propose some little refactoring of your code:
- no need for copying BLine (and deleting it at the end)
- then set BLine outsied the ContSet loop
Option Explicit
Sub main()
    Dim b As Long, c As Long
    Dim IntPt As Variant
    Dim BLine As AcadEntity, CLine As AcadEntity
    Dim BarrSet As AcadSelectionSet, ContSet As AcadSelectionSet
        For c = 0 To ContSet.Count - 1
            Set CLine = ContSet.Item(c)
            IntPt = BLine.IntersectWith(CLine, acExtendNone)
            If UBound(IntPt) <> -1 Then
                ThisDrawing.ModelSpace.AddCircle CLine.EndPoint, 1
            Else
                MsgBox "ASDFASDF"
        Next
    Next
End Sub
MakCADD
from
ubound(IntPt)
you can verify the number of intersection points
