Int() problem
Int() problem
Int() problem
i am writing code for convert inch to feet. In my code:
feet = Fix(InchesInput \ 12)
the code works fine, except when it comes 11'-11 1/2" (143.5 inches) or 9'-11 1/2" (119.5 inches) etc (as long as 11 1/2"), the result becomes
feet = Fix(119.5\12) = 10??? (instead of 9!!!)
feet = Fix(143.5\12) = 12??? (instead of 11!!!)
How come?? Any suggestion??
thanks,
stab in the dark.. (new to vba, and not tested)
but.. why have the "fix" at all?.. does that not round off your result?
You're using \, which is the integer division operator. Operands are
rounded to integers before the division takes place, I believe.
Also, Fix'ing the result of integer division is redundant.
Use the normal division operator: /.
Fix(119.5 \ 12) == (119.5 \ 12) == 10
Fix(119.5 / 12) == 9
HTH,
Adam
? Fix(119.5 / 12)
9
Note the division symbol....they ARE different.
wrote in message news:5026055@discussion.autodesk.com...
thanks,
You guys are great!! Silly me.
Thanks,!!
