Inserting a block
Inserting a block
Inserting a block
Hi all,
I am having a problem getting the block I am inserting to come in in the proper place. As you can see by the code below, the block should come in at 0,0. But, for some strange reason it comes in at like 1", 87'-3". I have tested manually inserting the same block with the same insertion point and it works fine. I have also changed the numbers to 0,0 and it works fine. Am I missing something? I am not sure what is going on here.
Dim insertFUSsc5(0 To 2) As Double
insertFUSsc5(0) = 1: insertFUSsc5(1) = 1: insertFUSsc5(2) = 0
Set acadFUSblock2 = ThisDrawing.ModelSpace.InsertBlock(insertFUSsc5, "x:\cad standards\blocks\R2000\masks\FUS_11x17_Nar_FT54.dwg", 5, 5, 5, strArrowRot)
The above code is just a small snipit. All of the string names are declared somewhere else.
Thanx for any help you can give.
Rob
Hello Rob,
For a proper use of InsertBlock i think you have to declare your variables
like this:
Using a Variant instead of a Double for the InsertionPoint works.
Is strArrowRot declared as a String? Should this not be a Double?
By the way: When you set the X and Y value of the InsertionPoint 1 instead
of 0, the block will never be inserted at the origin.
Happy New Year,
Henk Loonstra
www.CadFancy.myweb.nl
style="BORDER-LEFT: #000000 2px solid; MARGIN-LEFT: 5px; MARGIN-RIGHT: 0px; PADDING-LEFT: 5px; PADDING-RIGHT: 0px">
Hi
all,
Set acadFUSblock2 =
somewhere else.
Rob
