insertblock problem
09:44 AM
I have the following code:
Sub leftDoor(blockname)
Rem dimension all the variables
Dim hp(0 To 2) As Double 'hp is the hing point
Dim lp(0 To 2) As Double 'lp is the latch point
Dim varret As Variant
Dim blockobj As AcadBlockReference
Dim truefalse As Boolean
Dim entry As AcadLayer
Dim contnue As Boolean
Dim onerunthru As Boolean
Dim doorscale As Double
Dim doorangle As Double
Dim Msg, Style, Title, Help, Ctxt, Response, MyString
Rem initialize the variables
contnue = True
truefalse = False
layertouse = ""
onerunthru = False
Rem ** Do While contnue = True
Rem check to see if a door layer exists
For Each entry In ThisDrawing.Layers
If (entry.Name = "Door" Or entry.Name = "DOOR" Or entry.Name = "door" Or entry.Name = "Dr" Or entry.Name = "DR" Or entry.Name = "dr") Then
truefalse = True
layertouse = entry.Name
Next
If truefalse = True Then
Rem insert the correct door block once the inserttion layer is known
Rem get the hinge point
varret = ThisDrawing.Utility.GetPoint(, "Enter the hinge point: ")
hp(0) = varret(0)
hp(1) = varret(1)
hp(2) = varret(2)
Rem get the latch point
varret = ThisDrawing.Utility.GetPoint(, "Enter the latch point: ")
lp(0) = varret(0)
lp(1) = varret(1)
lp(2) = varret(2)
Rem calculate the scale for the door block
doorscale = Sqr(((hp(0) - lp(0)) ^ 2) + ((hp(1) - lp(1)) ^ 2) + ((hp(2) - lp(2)) ^ 2))
Rem calculate the angle to insert the block
Rem doorangle = ThisDrawing.Utility.AngleFromXAxis(hp, lp) + (3.14159 / 2)
Set blockobj = ThisDrawing.ModelSpace.InsertBlock(hp, blockname, doorscale, doorscale, doorscale, doorangle)
Rem set the inserted block to the correct door layer
blockobj.Layer = layertouse
blockobj.Update
contnue = False 'set a variable to exit out of the loop
Else
Rem ask the user if they want to create a layer or use an existing layer.
If onerunthru = False Then
Msg = "A door layer does not exist. Do you want to create one or use an existing layer?"
Style = vbYesNo + vbCritical + vbDefaultButton2 ' Define buttons.
Title = "Error! No Layer for Doors" ' Define title.
Response = MsgBox(Msg, Style, Title)
If Response = vbYes Then ' User chose Yes.
Rem if they want to use an existing layer, then use the dialog box
createdoordlg.Show
truefalse = False
onerunthru = True
Else
Rem display an error message if they answered NO
MsgBox "I can not create the door without a layer to insert the Door onto. I will now exit this command!"
contnue = False
Rem ** Loop
End Sub
This will insert the block fine, but it rotates all the blocks with the same name by 90 degrees. Why is it doing this?
contnue = True
truefalse = False
layertouse = ""
onerunthru = False
truefalse = True
Next
hp(0) = varret(0)
hp(1) = varret(1)
hp(2) = varret(2)
lp(0) = varret(0)
lp(1) = varret(1)
lp(2) = varret(2)
blockobj.Update
Else
createdoordlg.Show
truefalse = False
onerunthru = True
Else
contnue = False
Rem ** Loop
End Sub
