insert block in modelspace while in paperspace
01:31 PM
Hi. Is there any way to insert a block in modelspace while active layout is paperspace and the cursor is inside a viewport? I have this as my code:
space = ThisDrawing.GetVariable("tilemode")
If (space = 1) Then
Set bref = ThisDrawing.ModelSpace.InsertBlock(pt, bnam, 1#, 1#, 1#, 0)
Else:
Set bref = ThisDrawing.PaperSpace.InsertBlock(pt, bnam, 1#, 1#, 1#, 0)
the routine inserts the block in paperspace when the active layout is paperspace even if the cursor is inside a viewport. Thank you.
If (space = 1) Then
Else:
