Importing .dxf files with VBA
RalphBrown99
RalphBrown99
Hi:
I am trying to import-copy- a group of .dxf files (more than 50) using VBA. The idea is to copy the data from this files in anyway, either opening the file using copy command in the original files and the paste command in the final file, using insert or the regular import option.
Is this possible to write a piece of code with this functionality?
Rafael
adam.nagy
Autodesk Support
Autodesk Support
Have a look at AcadDocument.Import()
I hope this helps.
Cheers,
Adam Nagy
Autodesk Developer Network
Adam Nagy
Autodesk Platform Services
