If ... then
If ... then
Message 1 of 16
If ... then
I need some help,
I want to program the following things:
if value 1 <= 3300 then
x = 44
y = 142
if 3300 < value 1 <=3800 then
x = 58
y = 170
if 3800 < value 1 <= 5100 then
x = 58
y = 192
I did program this one, but when I use it to draw, then autocad always uses the last one (58, 192) even if my value 1 is <3300.
How do I progrm it right?
thx
Replies (15)
Message 2 of 16
Firstly, if you are trying to use "value 1" as a variable name, it is not
allowed because of the space. Replace "value 1" with "value1" in your
program.
Second... here's your If-Then in a working format.
' make sure you handle value1 < 0, unless you know that
' it could never happen
if value1 <= 3300 then
x = 44
y = 142
elseif value1 <=3800 then 'you know it's > 3300
x = 58
y = 170
elseif value1 <= 5100 then 'you know it's > 3800
x = 58
y = 192
else
'you should handle value1 > 5100, unless
' you know it could never happen
endif
Good luck,
James
Message 3 of 16
Quick fingers James beat me (and I would defer to his expertise any day) but
just for variety (and since I already wrote this out and tried it....)
Sub TEST2()
Dim VALUE1 As Integer
VALUE1 = 5550
Dim X As Integer
Dim Y As Integer
Select Case VALUE1
Case Is <= 3300
'if value 1 <= 3300 then
X = 44
Y = 142
dp X
dp Y
Case Is <= 3800
'if 3300 < value 1 <=3800 then
X = 58
Y = 170
dp X
dp Y
Case Is <= 5100
'if 3800 < value 1 <= 5100 then
X = 58
Y = 192
dp X
dp Y
Case Else
dp "OTHER"
End Select
End Sub
sub dp(str)
debug.print str
end sub
hth
Mark
"SabrinaCollstrop" wrote in message
news:f16e3e6.-1@WebX.maYIadrTaRb...
> Hi,
> I need some help,
> x = 44
> y = 142
> x = 58
> y = 170
> x = 58
> y = 192
> thx
Message 4 of 16
Sabrina,
Aside from the variable name problem, it sounds
like
a select case would be more appropriate than
an if statement:
Select case value1
case is <= 3300
x = 44
y = 142
case is <=3800
x = 58
y = 170
case is <=5100
x = 58
y = 192
case else
'here you can put the default condtion
end select
I need some help,
x = 44
y = 142
x = 58
y = 170
x = 58
y = 192
thx
Message 5 of 16
The draw of the dark side is powerful
<g>
Bobby C. Jones
href="http://www.AcadX.com">www.AcadX.com
Sabrina,
like
an if statement:
Select case value1
case is <= 3300
x = 44
y = 142
case is <=3800
x = 58
y = 170
case is <=5100
x = 58
y = 192
case else
condtion
end select
I need some help,
x = 44
y = 142
x = 58
y = 170
x = 58
y = 192
thx
Message 6 of 16
great minds work alike!
ha ha
"Doug Broad" wrote in message
news:CED30DCE21C047AE68FC41577A31A0DF@in.WebX.maYIadrTaRb...
> Sabrina,
> Aside from the variable name problem, it sounds like
> a select case would be more appropriate than an if statement:
Message 7 of 16
Sorry Mark,
I should have looked at your post more closely. My
post seems superfluous. 😉
Doug
"Mark Propst" wrote in message
news:73A7B48119BE123C267FA5673EEEFCB8@in.WebX.maYIadrTaRb...
> ha ha
> > Sabrina,
Message 8 of 16
Yes Master Bobby,
Hmmm.  You need a more
imposing moniker. 😉
<g>
Bobby C. Jones
<snip>
Message 9 of 16
Far from it!
I'm relieved to have my 'wild axx guess' confirmed by someone of your
stature!
Always glad to hear your view!
Mark
news:D8EF6F74CBC80D4394D0830C8E5FD4AA@in.WebX.maYIadrTaRb...
> Sorry Mark,
> Doug
Message 10 of 16
baba bobby?
news:528FCAFBC818DF2B46B3B8B0D1386CEC@in.WebX.maYIadrTaRb...
> Yes Master Bobby,
> Hmmm. You need a more imposing moniker. 😉
> "Bobby C. Jones" wrote in message
news:E48448F901BDE8CDF9DA6944A35B8057@in.WebX.maYIadrTaRb...
> Bobby C. Jones
> www.AcadX.com
Message 11 of 16
Mark,
I don't know whether DP is actually a utility you use or just something you
wrote this one time, but I thought it was nifty and couldn't resist adding
to it.
I know I should just throw this e-mail out to spare myself the
embarrassment, but maybe I can save someone, somewhere, from Debug.Print
"carpal tunnel"... and yes, I know that with Auto-Complete it only takes
about 5 keystrokes to debug.print something anyway 🙂
Hmmm... this might be the start of a Development_Utility module that I bring
into new projects ...
James
Sub dp(ParamArray strs() As Variant)
Dim i As Long
If UBound(strs) = -1 Then Debug.Print: Exit Sub
For i = LBound(strs) To (UBound(strs) - 1)
Debug.Print strs(i) & ", ";
Next
Debug.Print strs(UBound(strs)) & ""
End Sub
Sub testDP()
Dim x As String, y As Double
x = "xxxx": y = "1234.12958"
dp x
dp
dp x, y, x, y
End Sub
Message 12 of 16
Anybody have any idea how to parse this XML document?
Big Imposing Scary Bob
Not my favorite. It just doesn't have a ring to it.
baba bobby
If this one sticks, I'm hunting you down Mark!
Stress Ball Buster
Take this one where you want...but probably not on this
server.
big
Bobby C. Jones
www.AcadX.com
news:1EEFB69EBAE8E7E16A46A501894E6714@in.WebX.maYIadrTaRb...
> baba bobby?
> > Yes Master Bobby,
> > Bobby C. Jones
> > www.AcadX.com
Message 13 of 16
ROFLOL. Babba Bob. Has a ring to it.
news:160D1C9A7BA9232ED67EC529720A7190@in.WebX.maYIadrTaRb...
Message 14 of 16
this must be one of those symbiotic moments
Actually, the one i really use is
Sub dp(str)
Dim doc As AcadDocument
Set doc = ThisDrawing
Debug.Print str
doc.Utility.prompt vbCrLf & str & vbCrLf
Set doc = Nothing
End Sub
and i've been wanting to add the automatic parsing of a point value but
haven't got around to it,
thanks for the momentum!
dp revised:
Option Compare Text
Option Explicit
Sub dp(str)
Dim i As Integer
Debug.Print TypeName(str)
Dim pointstr As String
pointstr = ""
If TypeName(str) = "string" Then
Debug.Print str
ElseIf TypeName(str) = "variant()" Then
If UBound(str) > 0 Then
For i = LBound(str) To UBound(str) - 1
pointstr = pointstr & str(i) & ", "
Next i
Debug.Print pointstr
doc.Utility.prompt vbCrLf & pointstr & vbCrLf
Set doc = Nothing
End Sub
Mark
"James Belshan" wrote in message
news:F71B1B21D6445C773542574E57DA025B@in.WebX.maYIadrTaRb...
> Mark,
you
> to it.
bring
> James
> Dim i As Long
> Next
> End Sub
> Sub testDP()
> dp x
> dp
> dp x, y, x, y
> End Sub
Message 15 of 16
My current AutoCAD VBA stature: Knee high to a grasshopper.
I'll try to live up to your expectations. 😉
news:1E9425F743BF67AD726407EB2F1C656E@in.WebX.maYIadrTaRb...
> Far from it!
> stature!
> Mark
Message 16 of 16
news:9658067EE305A4FE71B81CEC62DDE6C3@in.WebX.maYIadrTaRb...
> dp revised:
revised again:
Sub dp(str)
Dim i As Integer
pointstr = ""
Debug.Print str
ElseIf Right((TypeName(str)), 2) = "()" Then
Next i
Set doc = Nothing
End Sub
