Icons for Toolbars
Icons for Toolbars
Icons for Toolbars
Can anyone please help I have created a new tool bar and I am trying to
assign a Bmp
image to the button.
I have tried the SetBitMap and GetBitMap, but this seems to only control
the size of the image not the image itself
This is my code to create the toolbar
LoadMacro = Chr(45) & "vbaload" & Chr(32) & "TitleBlockAttributes.dvb" &
Chr(32)
RunMacro = Chr(45) & "vbarun" & Chr(32) & "TitleBlockAttributes" & Chr(32)
Set LoadButton = newToolBar.AddToolbarButton("", "Load_Macro",
"LoadingMacro", LoadMacro)
Set RunButton = newToolBar.AddToolbarButton("1", "Run_Macro",
"RunningMacro", RunMacro)
Regards
Steven Houghton
Try something like this, although it's similar to what you have, it works
here. You may just need to put the bitmap name in quotes:
SmallBitmap = "16x16.bmp"
LargeBitmap = "32x32.bmp"
LoadButton.SetBitmaps SmallBitmap, LargeBitmap
-- Walter -- http://www.ActiveDwg.com
Steven Houghton wrote in message
news:[email protected]...
> assign a Bmp
> Chr(32)
> Regards
> Steven Houghton
LoadButton.SetBitmaps "Load.bmp", "Load1.bmp"
where load and load1 are the name of toolbuttons in a resource dll or the
full path to your saved bitmap
> assign a Bmp
> Chr(32)
> Regards
> Steven Houghton
Once, when i had a lot of free time, i've wrote little routine to convert
the bitmap files into code, so you can insert the bitmap files as a little
data string into your code and into your DVB file. It also has some example
code to assign the bitmaps to your toolbarbuttons.
You can download this lill'routine at
http://www.jwk.mbit.nl/codenoodles/icon2code.html
Maybe this will help you a bit.
wkr, jwk
Steven Houghton had the next bright idea:
>assign a Bmp
>Chr(32)
>Regards
>Steven Houghton
You ask a silly question, you get a technical answer...
________________________________________________________
