I need VBA code to loop in layouts only
I need VBA Code to know how to loop in layouts object only to print all layouts except model space layout, inside the Current opened file
This should get you started.
Private Sub LayoutsOnly()
Dim objLayout As ACADLayout
For Each objLayout In ThisDrawing.Layouts
If objLayout.Name = "Model" Then
MsgBox "Skipping tab"
Else
MsgBox "Plot layout tab"
Next objLayout
End Sub
I support two teams: The Red Sox and whoever beats the Yankees.
wrote in message news:4845946@discussion.autodesk.com...
in addition, you may also want to review the plot config for each...
[code]
Sub test()
Dim oLayout As AcadLayout
For Each oLayout In ThisDrawing.Layouts
If oLayout.Name <> "Model" Then
With oLayout
.ConfigName = "HP DesignJet 800.pc3"
.UseStandardScale = True
.StandardScale = ac1_1
.ScaleLineweights = True
.PlotType = acExtents
.PlotRotation = ac0degrees
.CanonicalMediaName = "User1309"
.PlotWithPlotStyles = True
.StyleSheet = "Oberer.ctb"
.RefreshPlotDeviceInfo
End With
Next
End Sub
[/code]
Thanks alot It's working
there is another Example
If strcomp(objLayout.Name,"model",VBTextstring) = -1Then
MsgBox objLayout.Name
Next objLayout
End Sub
apreciate your Effort ,
Thanks.....
