I need to extract a single attribute.
I am fairly new in the VBA programming. I am trying to extract a single attribute and the program I have extracts all the attributes in my drawing. Here is the code can someone point me in the right direction.
Private Sub CommandButton1_Click()
Dim ACADObject As AcadEntity
Dim element As Object
Dim ArrayAttributes As Variant
Dim TagString As String
TagString = "BR_ST#"
Dim I As Integer
For Each element In ThisDrawing.ModelSpace
If element.EntityType = 7 Then
ArrayAttributes = element.GetAttributes
For I = LBound(ArrayAttributes) To UBound(ArrayAttributes)
MsgBox "Attribute Text String : " & ArrayAttributes(I).TextString
UserForm1.Hide
Next
Next
End Sub
The attributetag "BR_ST" is the attribute I want to isolate, it is the first one that lists in the message box's. You can email me direct at [email protected]
is the attribute in a certain block reference? what
is the block name?
that will narrow down the search
programatically
do a filtered selection for the block instead of
iterating everything in model space
but in your code as is, you could do something
like
    If element.HasAttributes
then
       ArrayAttributes =
        For I =
    If ArrayAttributes(I).TagString = "tag you want"
then
    UserForm1.Hide
    End if
    Next
    End if
I
    Dim
    Dim I As Integer
    For
    If
    ArrayAttributes =
    For I =
    UserForm1.Hide
    Next
    Next
End Sub
[email protected]
Yes my attribute is in the block called "BlockbusterBorder" Your code addition works out well. My next step is to put the text in Textbox1 which is easy. After that I am compiling a master list I might need help on but I want to try first on my own. Thanks for the info.
