How to update blocks inserted as wblocks ?
Message 1 of 12
Hello VBA users,
I need to update blocks inserted as wblocks.
I used to apply the DefineBlock method provided with AcVbEXT library when I
was working under AutoCAD 14.01.
Since I've installed A2K, I don't reach to call the
ACVBEXTLib.ActiveXExtension application. The second code line listed below
generates an error :
Dim appACVBEXT As ACVBEXTLib.ActiveXExtension
Set appACVBEXT =
ThisDrawing.Application.GetInterfaceObject("ActiveXExtension.Application.1")
Does anybody knows if the AcVbEXT library is still compatible with A2K ?
Otherwise, how can I redefine wblocks without sending LISP commands ?
Thanks for any help,
Serge.
Replies (11)
Message 2 of 12
What's a "wblock"? WBlock is a command.
__
"Serge Heinrich" wrote in message
news:876ecj$ia75@adesknews2.autodesk.com...
> Hello VBA users,
when I
below
> Set appACVBEXT =
1")
> Serge.
Message 3 of 12
I've not attempted this Serge, so I don't know if it will work. But in
normal AutoCAD, you can redefine a block by just inserting a file with the
same name as an existing block. Have you tried using the InsertBlock method
with an updated version of the file that created your block in the first
place?
> Hello VBA users,
I
> Set appACVBEXT =
> Serge.
Message 4 of 12
Yes, Frank, it works. Thanks for your help.
But in AutoCAD you can cancel the insertion of the new block reference after
having confirmed the message "This block aleready exists. Do you want to
redefine it ?", so you can update the block without creating a new
reference.
With VBA, if I use the InsertBlock method, it will create a new reference
that I'll have to delete.
In order to update all the blocks of the drawing, I'd have preferred to use
a method which applies to Block objects (such as DefineBlock provided with
AcVbEXT library) in only one loop "For each objBlock in ThisDrawing.Blocks",
rather than the InsertBlock method which applies to BlockReference objects,
that will constrain me to loop in every block references in the ModelSpace
and in every PaperSpace layouts.
Frank Oquendo a écrit dans le message :
877509$l0f16@adesknews2.autodesk.com...
method
> place?
Message 5 of 12
Paul,
In fact, inserting a block or a wblock reference in VBA uses the same method
"ThisDrawing.ActiveSpace.InsertBlock(...)", and the result is the same: a
new block reference.
But in the first case you specify the name of a block that aleready exists
in the drawing, and in the second case you specify the path and the name of
a drawing that will be used to create a block (after the insertion, there's
no way to see which method has been used, because there's no dynaminc link
between the block and the file ; it's not like an Xref).
Paul Turvill a écrit dans le message :
8774qe$l0g22@adesknews2.autodesk.com...
Message 6 of 12
No problem. Just do something like this:
For Each blk in ThisDrawing.Blocks
Set blkref = ThisDrawing.ModelSpace.InsertBlock( & blk.name &
".dwg", yada yada)
blkref.Delete
Next
Get free software and more at: http://www.stonemedia.com/~franko
news:878u27$t591@adesknews2.autodesk.com...
after
> reference.
use
objects,
the
> method
> > place?
Message 7 of 12
BTW, be sure to screen out the ModelSpace and all PaperSpace blocks.
"Frank Oquendo" wrote in message
news:879uto$2q819@adesknews2.autodesk.com...
> ".dwg", yada yada)
> blkref.Delete
> Next
> after
> > reference.
reference
> use
with
> objects,
ModelSpace
> the
> > method
first
> > > place?
Message 8 of 12
What do you mean ?
Aren't blocks childs of Document object ?
I think that I just have to screen out ThisDrawing.Blocks. Tell me if I'm
wrong.
Thanks a lot for your help.
879var$2qd17@adesknews2.autodesk.com...
blk.name
> > ".dwg", yada yada)
> > blkref.Delete
> > Next
> > after
to
> > > reference.
> reference
to
> > use
> with
> > objects,
> ModelSpace
in
with
> > the
> > > method
> first
> > > > place?
Message 9 of 12
ModelSpace and and all Layouts (PaperSpace) are blocks. These blocks will
show up in the Blocks collection along with all the others. Just check the
name of each block as you iterate through the collection and leave the ones
that contain the string "ModelSpace" and "PaperSpace" alone. Another note:
be sure to use InStr, not = since all the layouts have "PaperSpace" in them
but the non-current ones have a numeral appended.
http://msnhomepages.talkcity.com/protectionfault/foquendo
news:87ed3p$i2a20@adesknews2.autodesk.com...
> What do you mean ?
> wrong.
> blk.name
> > > ".dwg", yada yada)
> > > blkref.Delete
> > > Next
reference
> > > after
want
> to
> > > > reference.
> > reference
> to
> > > use
provided
> > with
> > > objects,
> > ModelSpace
But
> in
> with
> > > the
InsertBlock
> > > > method
> > first
> > > > > place?
Message 10 of 12
You don't have to compare strings. The Block object has
an IsLayout property that returns True if the block is
a layout.
Serge Heinrich wrote:
> What do you mean ?
> wrong.
> blk.name
> > > ".dwg", yada yada)
> > > blkref.Delete
> > > Next
> > > after
> to
> > > > reference.
> > reference
> to
> > > use
> > with
> > > objects,
> > ModelSpace
> in
> with
> > > the
> > > > method
> > first
> > > > > place?
/* Tony Tanzillo Design Automation Consulting */
/* Programming & Customization for AutoCAD & Compatibles */
/* tony.tanzillo@worldnet.att.net */
/* http://ourworld.compuserve.com/homepages/tonyt */
Message 11 of 12
Good point. I forgot about that.
"Tony Tanzillo" wrote in message
news:389B84BF.A728F2CC@worldnet.att.net...
> a layout.
> > What do you mean ?
I'm
> > wrong.
> > blk.name
> > > > ".dwg", yada yada)
> > > > blkref.Delete
> > > > Next
reference
> > > > after
want
> > to
> > > > > reference.
> > > reference
preferred
> > to
> > > > use
provided
> > > with
> > > > objects,
> > > ModelSpace
message :
But
> > in
file
> > with
> > > > the
InsertBlock
> > > > > method
the
> > > first
> > > > > > place?
Message 12 of 12
Toni,
Is the AcVbExt extension compatible with A2K ?
I've found the AcadX extension on your web site, but it doesn't provide the
DefineBlock method.
Do you consider that it's no more useful since it is possible to update
blocks by inserting and deleting them ?
Tony Tanzillo a écrit dans le message :
> a layout.
