How to set center of a viewport a specific point of a model space
parikhnidi
parikhnidi
Hi Friends,
I have created a viewport in a paperspace using -
Set pviewportObj = ThisDrawing.PaperSpace.AddPViewport(loc, 100, 500)
pviewportObj.ViewportOn = True
Now I want to set the center of this viewport a specific point of the modelspace. How do I do that?
Nimish
parikhnidi
Well after some struggle, I realize that there is no way to set this in AutoCAD VBA.
However, I found a crude way where, I activated the viewport in question in VBA using ThisDrawing.MSpace = True and then use ZoomCenter method to establish center and magnification. It worked well for me.
I wish there should be some property something like PSpaceViewPort.ModelSpaceCenter and PSpaceViewPort.ModelSpaceHeight.
With more emphasis on .NET development, and VBA being visible only in rear view mirror, I don't think I would like to send this as wish list item.
Nimish
PS: I am starting to switch my development to .NET but it will be a very long process.
norman.yuan
Have you looked at Target property of AcadPVireport/Viewport/View object? That is what you need to set the center point of the ModelSpace one can see through the viewport. Then with StandardScale/CustomScale property you can achieve the effect of zooming by "ZOOM" command.
Norman Yuan
Drive CAD With Code
parikhnidi
Thanks Norman for the suggestion.
I tried what you suggested to no avail. I believe, I will have to live with the work around as indicated earlier.
Nimish
Sea-Haven
I dont agree with you look at a dump of properties they are not read only.
Select object: ; IAcadPViewport: IAcadPViewport Interface
; Property values:
; Application (RO) = #<VLA-OBJECT IAcadApplication 00007ff6cb551e30>
; Center = (397.414 301.03 0.0)
; CustomScale = 0.485444
; Height = 473.195
; Target = (610.872 453.508 0.0)
; TwistAngle = 0.0
; Width = 776.284
