How to "select" an selection set
ilovejingle
Message 1 of 12
ilovejingle
I have a AutoCAD drawing which consists a lot of block references with attributes. what I want to do is to be able to select some of the blocks by certain rules, then select them, and user can decide what attributes they want to change. I have some code to scan the entire drawing and create a selection set to put all the qualified block references in, the problem is I cannot "Visually" select them so that I can modify the attributes on AutoCAD properties window.
The problem:  How to select all entities in a selectionset. I try to use the following method, but it seems that it only select all objects in modelspace.
    'ss is the selection set created.
    'msgbox ss.count
    'there are correct number of elements in the selection set.
    ss.Select acSelectionSetAll
    ss.Delete
    ThisDrawing.SendCommand "Select p " & vbCrLf
Replies (11)
Message 2 of 12
norman.yuan
There was a very similar topic discussed recently, the code sample provided in that discussion could be what you need with minor modification:
https://forums.autodesk.com/t5/visual-basic-customization/vba-return-selection-to-user-for-further-m...
HTH
Norman Yuan
Drive CAD With Code
Message 3 of 12
ilovejingle
Thanks for the reply
I do look into your code and the option of using selection filter to
achieve it, the problem is that object can be added to selection set for
different reasons, for my case, I was addeing block ref to my selection set
based on certain attribute values. I dont think it can be achieved using
available filters
iit looks like you need to run a selectall with filtered to make autocad
capture the previous selection
Message 4 of 12
norman.yuan
Base on my understanding of your original question, what you asked is, ONCE you have an AcadSelectionSet built, then you want all the entities in the SelectionSet highlighted AS IF they are selected by user, so that user can either issue a command against them, or use Property window to modify them. Am I correct on this? If yes, then the focus to my code from the other post for you is the LAST line:
ThisDrawing.SendCommand "SELECT" & vbCr & "P" & vbCr & vbCr
That is, it does not matter how you create a Selection set, using filter or not. SelectAll or not. Just build one in whatever code suitable to you.
For example, you can loop through all entities in ModelSpace to find certain entities and add them into a selectionset, something like this way:
Public Sub SelectSomethin()
  Dim ss As AcadSelectionSet
  Set ss=BuildSelectionSet()
  If ss.Count>0 Then
    ThisDrawing.SendCommand "SELECT" & vbCr & & "P" & vbCr & vbCr
  Else
    Msgbox "No entity selected!"
End Sub
Private Function BuildSelectionSet() As AcadSelectionSet
  Dim ent As AcadEntity
  Dim ents() As AcadEntity
  Dim i As Integer
  On Error Resume Next
  Set ss=ThisDrawing.SelectionSets("MySet")
  If ss Is Nothing Then
    Set ss=ThisDrawing.SelectionSet.Add("MySet")
  Else
    ss.Cear
  For Each ent In ThisDrawing.ModelSpace
    If IsMyTarget(ent) Then
      ReDim Preserve ents(i)
      Set ents(i)=ent
      i=i+1
  Next
  If i>0 Then
    ss.AddItem ents
  Set BuildSelectionSet = ss
End Sub
Private Function IsMyTarget(ent As AcadEntity) As Boolean
   '' Use whatever logic to determine whether this entity show be
   '' added into the SelectionSet or not
   Is MyTarget=True/False
End Function
Norman Yuan
Drive CAD With Code
Message 5 of 12
ilovejingle
Thank for the reply, but I am afraid it does not work as you described.
You do understand my intention 100% correctly, I am using exactly the code you write here.
    If testCase Then
        ThisDrawing.Utility.Prompt vbLf + "Find :" + objBlk.EffectiveName
        ReDim Preserve objlist(i)
        Set objlist(i) = objBlk
        i = i + 1
    If UBound(objlist) > 0 Then ss.AddItems (objlist)
    ThisDrawing.Utility.Prompt vbLf + "Total Find :" + CStr(ss.count)
The code runs correctly, and
ss.Count
is able to capture the correct amount of block refs I am inserted ,but it won't be recognized as a previous selection by AutoCAD. here is the command line results.
Total Find :50
Command: SELECT
Select objects: P
No previous selection set.
Message 6 of 12
norman.yuan
Ah, I now see where the problem is: it looks like, AutoCAD only register "Previous" selection set when AcadSelectionSet.Select()/SelectXXXX() method is called and only remember the entities selected by the method call. entities added/removed via code does not reflect in the "Previous" selection set.
So, it looks like you need to come up with very fine-tuned selection filters to call on Select() method. Unfortunately for your case, if the blocks you are trying to select are dynamic ones, you probably cannot apply block name filter, thus very difficult to select with Select(acSelectionSetAll, filters, filterValues...) method.
Norman Yuan
Drive CAD With Code
Message 7 of 12
ilovejingle
Thanks for the reply anyway.  looks like there is no easy way of doing this.
I think of a work around, which manipulate the visibility status of the block, since I am not working with dynamic blocks and not using the visibility properties at all for Xref files.
It is not a perfect and flawless solution but works for me.
  For Each objEnt In ThisDrawing.ModelSpace
        If TypeOf objEnt Is AcadBlockReference Then
            Set objblk = objEnt
            AltEntVisibility objblk, True
            If isTheBlock(objblk, strOpt, strIdentKey, isExact) Then
                ThisDrawing.Utility.Prompt vbLf + "Find :" + objblk.EffectiveName
                Set objlist(i) = objblk
                AltEntVisibility objblk, False
                i = i + 1
    Next
    If i > 0 Then
        ss.AddItems objlist
'   Create Temp SS to be able to select things so that AutoCAD can cache the selection set
    Dim newSS As AcadSelectionSet
    Set newSS = A_FuncLib.CreateSS("TempSS")
'   Create an filter type and value
'   Filter on the element's visibility sates
'   Previous qualified blocks has been put to invisible.
    Dim fCode(0 To 1) As Integer
    Dim fData(0 To 1) As Variant
    fCode(0) = 0: fData(0) = "INSERT"
    fCode(1) = 60: fData(1) = 1
    newSS.Select acSelectionSetAll, , , fCode, fData
'   Make the everything in ss visiable again
    For Each objEnt In ss
        AltEntVisibility objEnt, True
    Next
    Dim isSSEmpty As Boolean: isSSEmpty = (newSS.count <= 0)
'   Delete the newSS, so that AutoCad can cache the selection set as "Previous Selection Set"
    newSS.Clear: newSS.Delete
    If Not isSSEmpty Then
    Else
        ThisDrawing.Utility.Prompt vbLf + "Nothing Found!"
ExitNormal:
ss.Clear
ss.Delete
LockWindowUpdate 0
Exit Sub
Err:
ThisDrawing.Utility.Prompt vbLf + "Action Aborted !" + vbLf
GoTo ExitNormal
End Sub
Message 8 of 12
norman.yuan
Another way to do it might be a bit simpler. Here is the psuedo logic:
1. Loop through all entities to identify the target ones.
2. For each target entity, attach XData with given XData application name
3. Define selection set filter to select entities with XData application name
4. Create SelectionSet and call Select() to select all entities with the XData application name filter. At this point, AutoCAD register the SelectionSet as "Previous"
5. Remove the XData attached to those entities
6. Delete the selectionset, if desired
7. Now it is ready to call SendCommand "Select" & vbCr & "P" & ....
Norman Yuan
Drive CAD With Code
Message 9 of 12
brian_adams
could you public all the code/ it's a part of it only
I also want do make selection of precise object but i whant to do it useing ID of object
and i stucked
Message 10 of 12
serag.hassouna
Selecting a selection set visually for the user to interact with them is fairly easy in AutoLISP using a function called sssetfirst.
It has 2 arguments, the first one you need to set it to nil, and the second one is the variable that has the selection set identification bound to it.
However, you have an ActiveX selection set (called ss), so, the trick is to assign the members of ss to an AutoLISP selection set, this can be done by an AutoLISP function called vlaSel->Sel written by @Doaiena.
What remains finally is to invoke vlaSel->Sel, this can be done in 2 steps as follows:-
  1. Define vlaSel->Sel into your drawing.
    ThisDrawing.SendCommand "(defun vlaSel->Sel ( vlaSel / sel )" & vbLf & _
    "(setq sel (ssadd))" & vbLf & _
    "(vlax-for obj vlaSel" & vbLf & _
    "(ssadd (vlax-vla-object->ename obj) sel)" & vbLf & _
    ")" & vbLf & _
    "sel" & vbLf & _
    ")" & vbCr
  2. Invoke the function
    'Given that the selection set's name is MySSName
    ThisDrawing.SendCommand "(setq ss (vlaSel->Sel (vla-item (vla-get-selectionsets (vla-get-activedocument (vlax-get-acad-object))) ""MySSName"")))" & vbCr
    ThisDrawing.SendCommand "(sssetfirst nil ss)" & vbCr
    Or, if the selection set's name is stored in a variable, e.g. called SSName,
    'its name could be fetched with
    Dim SSName As String
    SSName = ss.Name
    the invocation statement is
    ThisDrawing.SendCommand "(setq ss (vlaSel->Sel (vla-item (vla-get-selectionsets (vla-get-activedocument (vlax-get-acad-object))) & Chr(34) & MySSName & Chr(34) & )))" & vbCr
Message 11 of 12
norman.yuan
If anyone wonders how the steps I suggested here would work or not, see this latest discussion on the same topic and my code solution.
Norman Yuan
Drive CAD With Code
Message 12 of 12
ivan_protsenko
Community Visitor
Community Visitor
I may be a bit late, but I think I've found a mistake in the invocation with variable name. Looks like you forgot quotation marks. It should be:
ThisDrawing.SendCommand "(setq ss (vlaSel->Sel (vla-item (vla-get-selectionsets (vla-get-activedocument (vlax-get-acad-object)))" & Chr(34) & MySSName & Chr(34) & ")))" & vbCr
