How to insert an anonymous block
Does anyone know how to insert an anonymous block into a drawing with VB/VBA
(Preferrably without 3rd party add-ins)
Brian D.
Do you mean "how to insert an anonymous block that already exists in the
blocks collection into modelspace" or do you mean "how to create an
anonymous block in the blocks collection"?
> Thanks,
> Brian D.
Well, I meant BlockReference, but with "anonymous" blocks (name="*ANY",
group 70 = 1),
I'm not sure the blocks collection is an issue.
"Minkwitz Design" wrote in message
news:3C88E3D1.5060007@ameritech.net...
VB/VBA
> > Thanks,
> > Brian D.
Hi Brian,
If I remember correctly, you can create a new anonymous block in the
collection by using the add method and giving it the name "*U", but the
issue that comes into play is if you already have multiple anonymous
blocks in the collection, since the insert method uses the name to
determine which block to insert. If it's a new block altogether, you can
use the add method setting it to a variable defined as acadblock, then
set the name property to another variable defined as string and insert
by that string variable. Something to the effect of:
dim blk as acadblock
dim bref as acadblockreference
dim Str as string
set blk = thisdrawing.blocks.add ("*U")
str = blk.name
'add geometry to block
set bref = thisdrawing.modelspace.insert (point, str, 1,1,1,0)
But once you lose a reference to it or if it already exists in the
drawing and is not new, you will have to differentiate the blocks by
objectid or some other method and try to grab the name property that way.
-Josh
> group 70 = 1),
> VB/VBA
>>>Thanks,
>>>Brian D.
Great ! That worked perfect. I was missing the part of
creating the block table entry first.
Brian D.
news:3C88FEF1.7000103@ameritech.net...
> Hi Brian,
> dim Str as string
> str = blk.name
> -Josh
> > group 70 = 1),
> > VB/VBA
> >>>Thanks,
> >>>Brian D.
