How to insert a Unicode character into a string?
Hi!
 I need to insert a registered brand character (®) into a string for a product model using code ("Model Name ®"). How do you handle Unicode in VB .NET?
Alfred.NESWADBA
imho you don't need any special things to do, just copy the character to your VB.NET code (from word or from any software that shows the symbol you want) and use it then.
For a text-object in AutoCAD that means then that it has to use a style that is set to a TTF.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
That simple,Ah?
Thanks Alfred. That worked like a charm.
